SUA dana 44 steering - JeepForum.com
post #1 of 9 Old 12-08-2012, 02:06 PM Thread Starter
czjeeper
Putting the narrowed HP dana 44 in soon. It is grand wagoneer width.
What pitman arm to use?
I'm thinking I will use the ruffstuff y link kit.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 9 Old 12-09-2012, 10:25 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Measure center of ball joint to center of steering arm location for the drag link.
Measure current Pittman arm sector shaft to drag link hole and the ball joint to tie Rod hole on the dana30, steering angles are pretty close with a d44/d30 so set up a simple ratio with the new steering arm length being your variable. Simple algebra.
ratmonkey is offline
post #3 of 9 Old 12-09-2012, 10:32 AM Thread Starter
czjeeper
Sorry, I don't think I explained my question.
Do I have to get a new pitman arm or ream my pitman arm? Or will mine work with the tie rod ends that come with the "one ton" kit?
Although, I didn't know how to do what you explaned, so thanks!
US Army combat vet
czjeeper is offline
post #4 of 9 Old 12-09-2012, 01:37 PM
ssyj94
Use a waggy pitman arm either reamed for 1ton tres or drilled out for heims depending on what your using. I've got a waggy 44 in my yj with a stock arm and it is to short to allow full steering(aka turning left sucks). Ive picked up a waggy arm to match the distance from the balljoint to the hole for the tre. This way it'll allow me to regain full steerring. Eyeballing it looks like it'll work hopefully I'll have time to get it on there before it gets to cold out.
My build:
ssyj94 is offline
post #5 of 9 Old 12-09-2012, 02:50 PM Thread Starter
czjeeper
Are all of the waggy arms the same, or do I need to get a certain year?
And, is an OEM length good for 4" SUA, or do I need a drop Waggy arm?
US Army combat vet
czjeeper is offline
post #6 of 9 Old 12-09-2012, 05:09 PM
ssyj94
We're reffering to the length of the arm from front to back not the vertical drop of the arm. The length will determine how much throw the steering sees. Your outer knuckle measurement dont know which your using will determine the pitman arm.
I'm not sure if all arms are the same but the one I've got from a later model waggy fits a yj box. Just get the stock waggy arm and put the tie rod over the knuckle. That should be fine with 4" of lift if not mock it up and change things till it works. Im not 100% sure since I run stacked heims and am stretched 3" upfront.
My build:
ssyj94 is offline
post #7 of 9 Old 12-09-2012, 05:45 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
whatever arm you get will likely need reamed for the heavier chevy drag link ends.
for the hp44(ford outers?) you'll need to select your actual arm in the manner i said.
post #8 of 9 Old 12-10-2012, 10:22 AM
mcannon111
why don't you just run crossover steering? you can keep your stock pitman arm, cause the high steer arm matches the throw of your pitman arm.
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #9 of 9 Old 12-10-2012, 11:15 AM Thread Starter
czjeeper
Yj
I'm SUA w/only 4" of lift.
In order to run 15" wheels I'm using F150 knuckles so I don't have high steer/flat top knuckles.
US Army combat vet
czjeeper is offline
