stroker - V8 - turbo - supercharger - JeepForum.com
post #1 of 10 Old 01-14-2013, 08:09 AM Thread Starter
jeepers1998
Tj stroker - V8 - turbo - supercharger
After many months of research a desission has been made. My 2004 tj will be receiving a V8. All the parts have arrived. Doner car was a 2000 camero Z28 with LS1 340 HP and 4L60E. Radiator set up from champion, adapters from Novak, More to come
jeepers1998 is offline
post #2 of 10 Old 01-15-2013, 02:44 PM
Line58
Are you planning to stroke/turbo the LS1? That would make for a beastly engine.
Line58 is offline
post #3 of 10 Old 01-15-2013, 03:41 PM Thread Starter
jeepers1998
No just swap in the V8, that will be enough power for me know.
post #4 of 10 Old 01-15-2013, 04:17 PM
tyvanwie
Can't wait to see it. Planning to do this down the line as well
tyvanwie is offline
post #5 of 10 Old 01-15-2013, 06:36 PM
Line58
Then why did you have those words in the title?
The Chevy V8 should be a beast in your Jeep. One of these years I want to drop a 5.3 in my TJ (prob in about 3 years). Good luck on the swap!
Line58 is offline
post #6 of 10 Old 01-15-2013, 08:57 PM Thread Starter
jeepers1998
I looked at stroking the 4.0 or adding a turbo or a super charger. after all the research we decided a V8 would be my best choice. Cost, aviability and weight we chose the LS1 over a hemi.
post #7 of 10 Old 01-15-2013, 10:05 PM Thread Starter
jeepers1998
Work begins on the V8 swap, we are replacing the trunion bearings, water and oil pump, rear main and all seals. Replacing stock exhaust manifolds with block hugger shorty headers. 4L60 will be torn down and checked and rear output adapter shaft installed.
post #8 of 10 Old 02-02-2013, 09:39 AM Thread Starter
jeepers1998
Tj
Have pulled the engine and transmission and transfer case, Modified the transfercase with a mini sye kit
post #9 of 10 Old 02-02-2013, 09:43 AM Thread Starter
jeepers1998
All the parts have arrived. Work begins preping jeep.
2013-01-11 15.35.22.jpg   2013-01-11 15.35.56.jpg   2013-01-11 15.36.11.jpg   2013-01-11 21.42.52-3.jpg
post #10 of 10 Old 05-27-2013, 11:58 PM
gotjeep12
good luck and Happy wrenching
gotjeep12 is offline
