sterling 10.25 vs dana 60? - Page 2 - JeepForum.com
post #16 of 25 Old 11-29-2012, 11:23 PM
jason m
Nothing but the facts
jason m's Avatar
Originally Posted by MO2500 View Post
I'd go D60. I've been looking into this myself and to run 37's you will likely have more into the D44 to make it live than you will the 60. Plus, if you ever decide to get a larger tire you will be setup already with axles that can handle them front and rear.
This, its easyer to upgrade tires than axle's.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #17 of 25 Old 11-30-2012, 05:13 AM Thread Starter
cherokeekid58
Thanks for the help guys. If i can get the sterling for free im gonn put that in. And now it looks like im on the hunt for a king pin D60
Thanks
Cheers
Jason
[QUOTE=sonoran_Tj
"If we collect data long enough, we may discover the root psychological cause for the "jeep thing".
So far it seems correlated to OCD and the need to look at one's poop."
cherokeekid58 is offline
post #18 of 25 Old 11-30-2012, 11:59 AM
MO2500
Thanks
Cheers
Jason
Don't rule out the newer superduty ball joint D60s. Aftermarket is catching up and they are a seriously stout axle. Stock knuckles are massive and Reid even said they would be making them if they were breaking, but they are not. The unit bearings can be bored out or purchased to use 35 spline stubs (35 spline inners come stock) and re-drilled to 8x6.5 lug pattern. You could even grab a matching set from a superduty, hp60 front and sterling rear, and leave the stock bolt pattern which is 8x170.
Instagram: @omsmike
MO2500 is offline
post #19 of 25 Old 11-30-2012, 12:04 PM
Imped
Imped's Avatar
I'll take a ball joint SDHP60 over a kingpin 78-79 HP60.....but that's just me.
OlllllllO
IndyORV
Imped is offline
post #20 of 25 Old 11-30-2012, 01:59 PM Thread Starter
cherokeekid58
The super duty axles got to be extremely expensive though. Probably way out of my budget.
[QUOTE=sonoran_Tj
post #21 of 25 Old 11-30-2012, 03:03 PM
connor0770
why not make a 14b an option? Cheaper than a 60/10.25 to build. Although if you only want 37's id def. recomend a shave kit.. With the shave it hangs about the same as my 8.8 on 35's
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #22 of 25 Old 11-30-2012, 03:23 PM
MO2500
You would be surprised. The price on king pin 60's is very inflated, at least in my area. You can pay less for a matched set of superduty axles if you search around, complete disc to disc.
Just an option to look into. Do a little research on the Superduty stuff and you may find it to be a better option. Like Imped, I'd take an SDHP60 over a KP now that aftermarket is supporting them a bit more. There are several variations of the SDHP60 based on years '99-04 and '05+. There is also a Super 60 that is serious beef! You want to avoid being fooled by a D50 as well if you decide to search for superduty axles which I believed they quit using in '02.
Instagram: @omsmike
MO2500 is offline
post #23 of 25 Old 11-30-2012, 03:43 PM Thread Starter
cherokeekid58
Thanks for the info guys, ill keep my search citeria very wide
[QUOTE=sonoran_Tj
post #24 of 25 Old 11-30-2012, 03:46 PM
Bama_WJ
Bama_WJ's Avatar
I'd go with a 60 as well.
And I did a small tech post about the 50 and 60 axles under 99-04 Ford SD trucks.
http://www.jeepforum.com/forum/f197/...l#post11800325
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #25 of 25 Old 11-30-2012, 04:23 PM
jason m
jason m's Avatar
My only beef with some of the super 60's is well the extra beef on the driver side. Theres alot of extra chunk cast to be removed
http://www.google.com/imgres?q=super...80&tx=95&ty=72
But once you get that figured out there very good axle's to build off. I would still put the late 80's KP Ford axle probally the best to build off as the pinion is very far over and well its a king pin cant beat that.
Jason.
jason m is offline
