Started the "Transmission Job", well OK, a complete Stroked Overhaul - Page 5 - JeepForum.com
post #61 of 147 Old 11-04-2012, 05:04 PM Thread Starter
W_A_Watson_II
Welded in the floor and door support patches. Now to patch the outer body panel, and then move to the rear of the tub for those patches.
Will
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is online now
post #62 of 147 Old 11-06-2012, 01:54 PM Thread Starter
W_A_Watson_II
Just a little work. I fabricated and welded in the outer panel patch for the drivers side door support area. Welding on this thin sheet metal just isn't my thing. I also removed the cracked/broken and cleaned up the cowl areas.
Will
Will Watson
post #63 of 147 Old 11-13-2012, 09:59 AM
AustinTexasXJ
1987 MJ Comanche
wow! super awesome job on this restore/build
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #64 of 147 Old 12-04-2012, 06:35 AM Thread Starter
W_A_Watson_II
No, I've not fallen off the face of the earth, I've been busy with Deer Season, Thanks Giving, Family and a few other things going on and have not had much time to work on the Jeep lately. I did get in a little work on the tub though. Finished the passenger side lower door support repair, and worked on the fuel pump access panel some more. Looks like my original plan of driving by Christmas is out the window, oh well, all is good though.
My "Transmission Job" & Stroker Build (My WEB Site)
Will Watson
post #65 of 147 Old 12-10-2012, 08:42 PM Thread Starter
W_A_Watson_II
Back to doing a little work on the Jeep. I made a reinforcement to install inside the rear tub body cross member to mount the CJ tail gate to. I was able to slide it in and through the rust hole on the passengers side before doing it's repair. I also reinforced/repaired the right rear tub mount and started closing off the rust hole.
Will
Will Watson
post #66 of 147 Old 12-16-2012, 09:15 AM Thread Starter
W_A_Watson_II
Started the exterior rear corner repair. Finally used my body panel clamps to hold the patch panels in place while I spot welded them in. They work pretty good, but my thin sheet metal welding skills aren't the best. I will need to finish welding them from the back/bottom side, but before I flip the tub, I spot welded in the final fuel pump cover side flanges. After a little more welding and some body filler the tub exterior is getting closer to sanding and painting.
My "Transmission Job" & Stroker Build (JeepForum)
Will
Will Watson
post #67 of 147 Old 12-16-2012, 05:23 PM Thread Starter
W_A_Watson_II
I finished attaching and welding the Fuel Pump Access Cover. Also welded the bottom side of the rear tub mount reinforcements I made.
Will
Will Watson
post #68 of 147 Old 12-17-2012, 03:35 PM Thread Starter
W_A_Watson_II
Finished the bottom side welding, and patching a few more places that I found. Next to remove some broken dash bolts, lower door hinges, and the brake pedal assemble to start prepping for paint, etc...
Will
Will Watson
post #69 of 147 Old 12-19-2012, 05:57 PM Thread Starter
W_A_Watson_II
Well, let me tell you, cleaning out the old carpet glue was no easy task. The glue is almost all gone now, and I've de-greased the inside of the tub and the engine side of the firewall as well. I've done the same trim/opening of the rear wheel wheels that I did to my brothers Jeep. This will allow easily up to 35" tires with out further trimming, so my current 31" might look a little out of place. I also fabricated the tailgate latch brackets from some 1/2" tubing and adding a weld to snap the latches against. The only metal work left on the tub is to fabricate/attach the tailgate straps. then I can prime, and fill the body spots in preparation for paint.
Will
Will Watson
post #70 of 147 Old 12-20-2012, 09:23 PM Thread Starter
W_A_Watson_II
This afternoon a little more cleaning, and then some bare metal priming. I also removed the glass out of the replacement windshield frame and getting it ready.
Will
Will Watson
post #71 of 147 Old 12-21-2012, 03:03 PM Thread Starter
W_A_Watson_II
I started the Filling and Sanding today, and should have it done tomorrow. Then to fab a couple of tailgate strap attachment plates (still need some dimensions though) and weld in the tub side plates.
Will
Will Watson
post #72 of 147 Old 12-22-2012, 08:30 PM Thread Starter
W_A_Watson_II
Spent a little time fabricating the tailgate cable brackets and attaching them. Need to finish welding them on and cleaning the welds and priming, but the work as planned. I also finished the body filler and first tub sanding. Next is to apply the fill primer and finish the sanding in preparation for paint.
Will
Will Watson
post #73 of 147 Old 12-23-2012, 04:35 PM Thread Starter
W_A_Watson_II
Well, the Tub is sanded and almost read for paint. A couple of spots that needed a little more filling to be sanded and I still need to sand the firewall. Then the bottom can be re-undercoated and the tub can be painted.
Will
Will Watson
post #74 of 147 Old 12-26-2012, 07:16 PM Thread Starter
W_A_Watson_II
The Tub is done and loaded for the trip to the Paint Booth when it's available. I've also got the Hood, Windshield and Tailgate sanded and ready for paint as well. Next comes the grill shell.
Will
Will Watson
post #75 of 147 Old 12-27-2012, 02:59 PM Thread Starter
W_A_Watson_II
The grill is disassembled, cleaned, initial sanding, and fill-primed. Now for it to dry and start sanding again so it's ready for paint.
Will
Will Watson
Do I "have" to drop the transmission skidplate to change mount? 26679cj5 TJ Wrangler Technical Forum 7 02-02-2012 08:16 PM
Are NV231's "one size fits all" or vehicle or transmission specific? skydiver30960 TJ Wrangler Technical Forum 3 07-01-2011 12:00 PM
Monster Transmission rebuild kits "parts Missing" jeffrey919r1 YJ Wrangler Technical Forum 1 01-13-2010 09:59 AM
"Stock" 32rh transmission flooded can't find breather vent CWBRider90 TJ Wrangler Technical Forum 7 01-07-2010 07:31 PM
Just started the "I go or the Jeep goes" fight johnroot01 Wrangler General Discussion 103 09-21-2009 05:56 AM
