stand alone fuel management - JeepForum.com
post #1 of 11 Old 04-04-2013, 11:09 AM Thread Starter
superman1456
Does anyone know of a standalone unit that will pass obd2 emmisions?
superman1456 is offline
post #2 of 11 Old 04-04-2013, 06:33 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
nope.
how about you fill in your vehicle information and give a little bit more detail on what you're trying to do.
ratmonkey is offline
post #3 of 11 Old 04-05-2013, 09:41 AM Thread Starter
superman1456
Its a 98 Cherokee with a 4.6l auto trans. I am looking for a stand alone system that has a dlc connected so it can pass nys inspections
post #4 of 11 Old 04-05-2013, 09:57 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
A well hidden piggy back that's very well programmed to only control spark and fuel may do the trick.
But a straight stand alone will not pass plug in inspection.
post #5 of 11 Old 04-05-2013, 11:12 AM Thread Starter
superman1456
OK that's exactly what I wanted to know
post #6 of 11 Old 04-09-2013, 11:04 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
I use standalone harness' in my motor swaps, and run OBD ports.
Depending on what you need to pass (EGR, how many o2 sensors, etc) it shouldn't be a problem.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #7 of 11 Old 04-12-2013, 02:59 PM
Morris4x4Center
Morris 4x4 Center
Morris4x4Center's Avatar
1987 YJ Wrangler
Why would you just wonder?
AEM standalone offers multiple maps. so you can use one map to pass emissions, another to run for everyday driving, and another one for performance and offroad chaos
Jeep Parts and Jeep Accessories
Toll Free: 877.553.5337 | Free Shipping on Orders Over $75!
PM us for any questions.
Morris4x4Center is offline
post #8 of 11 Old 04-12-2013, 05:05 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
does it work with the stock computer to pass the obdii plug in tests? not just sniffers?
post #9 of 11 Old 04-12-2013, 07:15 PM
leftlanetruckin
XJ on 37's
Most aftermarket harness' come with an OBDII port, so it is a non issue.
Martin
post #10 of 11 Old 04-19-2013, 02:02 PM
montelibre
1997 XJ Cherokee
I have just bought a MSX 3 Megasquirt and it will be able to pass any OBDII test with an appropriate tuning.
montelibre is offline
post #11 of 11 Old 04-19-2013, 08:55 PM
leftlanetruckin
XJ on 37's
My current project (LSx into a Range Rover) is running a standalone ECM and wiring harness. Harness came with output for a CEL and its own OBD port too. Would be absolutely no issue passing emission testing with the ECM set to run whatever you need to pass (EGR, o2 sensors, etc)
Martin
