Spring arch + other leaf Q's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Advanced Jeep Tech > Spring arch + other leaf Q's
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 03-22-2013, 11:10 AM   #1
Hussler
1992 XJ Cherokee
I need to get some new rear leafs for the XJ. The springs I've been running have been a mash up other the stock main, a local guy made an AAL and the rest are S10 I believe. From what I've always read, have a flat leaf spring will give you the best ride with a less than 45 degree shackle angle. Is this correct? Thats what I've been running for a year or so.
My leafs had a very little arch for a very long time (rode quite nice) and never sagged from their install height, then one day I noticed driveline vibes, they went S on me. Does more spring arch prevent this? Do flat springs wear out quicker?
Would it be time to consider an anti wrap bar?
I have to order new leafs, but I have shackle locators and extended shackles. I want 5" lift total. I'm eyeballing the OME 2" leafs. I imagine the OME springs are designed for stock shackle location, how would this affect the overall lift? I imagine because I can run a steeper angle it would be significantly less than 2".
Also would like to know whos running OME on the rocks and harder stuff/towing and how they have stood up
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline   Reply With Quote Quick reply to this message
Unread 03-22-2013, 11:23 AM   #2
egodfrey
egodfrey's Avatar
A traction bar will help the spring wrap alot for anything utilizing a SOA setup.
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline   Reply With Quote Quick reply to this message
