speedometer interchange information? - JeepForum.com
post #1 of 12 Old 03-25-2013, 12:50 PM Thread Starter
Jenyus425
so im putting a toyota transmission and transfercase in my 4.0 YJ. i know that the 4.2 yjs used a cable driven speedometer.
i have 2 questions
1. I know some people have swapped over to toyota cases, how are you running your speedometer/odometer?
2. will a 4.2 speedometer replace a 4.0 speedometer without modifying the gauge cluster?
Jenyus425 is offline
post #2 of 12 Old 03-26-2013, 06:29 PM Thread Starter
Jenyus425
bumpppppp
post #3 of 12 Old 03-28-2013, 12:33 PM
Siva283
The speedo reads from the transfer case not the engine. So yes a 4.2 speedo a 4.0 speedo and a 2.5 speedo are the same speedo's
Ask me how I know...
Siva283 is offline
post #4 of 12 Old 03-28-2013, 02:31 PM Thread Starter
Jenyus425
no thats not correct. 4.2 era wranglers had a cable driven speedo. 4.0 era wranglers have a speed sensor
post #5 of 12 Old 03-28-2013, 02:36 PM
Siva283
No it was cable driven through 91. In 92 the electronic speedos started. So I will be more precise. 4.2, 4.0, and 2.5 up to 91 are all the same. 91 had a cable driven speedo and an electronic sensor for the ECM. The speedo itself is still the same though. If you want to verify this just look up part numbers on your fav auto parts store website.
Siva283 is offline
post #6 of 12 Old 03-28-2013, 02:58 PM Thread Starter
Jenyus425
Ah I see now that I was wrong, thanks! So I could, theoretically use whatever sensor that's used and just figure out a way to adapt the cable and still use my stock 93 speedo?
post #7 of 12 Old 03-28-2013, 03:20 PM
Siva283
No the speedo gear is different I'd I am not mistaken
Sent from my Galaxy S3 using JeepForum
Siva283 is offline
post #8 of 12 Old 04-01-2013, 10:59 AM
brownbagg
1930 MK Compass
Go to junkyard and get an old toyoya apwwd cable. Cut the wms off the onner cable and solder to jeep cable, cut the nut off that screws to tranamission ans attach it to jeep cable
brownbagg is offline
post #9 of 12 Old 04-01-2013, 11:24 AM Thread Starter
Jenyus425
What do you mean by apwwd and wms?
post #10 of 12 Old 04-01-2013, 12:22 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Misspelling.
The mount hole and dimensions for the gear depth are the same since before the early 80's across many brands. Most bbrands actually, I believe.
ratmonkey is offline
post #11 of 12 Old 04-01-2013, 02:44 PM Thread Starter
Jenyus425
Okay cool that makes sense. I just bought a 77 cluster on eBay, speedo looks to be about the same size or close at least. Well see how it works! Thanks guys!
post #12 of 12 Old 04-14-2013, 03:32 PM Thread Starter
Jenyus425
seems to have worked!
77 toyota speedomeeter on righ jeep on left. they have almost exactly the same speed range so it should work perfectly.
mechanisms similar in size
looks factory! only difference is the yota doesnt have a trip meter, so i covered up the other slot. I clamped the two together and redrilled the jeep face for the toyota holes. everything is toyota except for the face
cant even tell
back dremeled out
