select trac to command trac - JeepForum.com
post #1 of 4 Old 08-29-2013, 09:46 AM Thread Starter
blazer160
1990 XJ Cherokee
Xj select trac to command trac
Hey , I swapped out my bad dana 30 front with solid axles(select trac) , to a dana 30 with command trac(2 piece axle shaft). It was free , but now 4wheel dr kinda screwy. Just wondering if can make work , or not worth trouble . Thnks in advance , any info would be appreciated , have both shop manuals(engine , electrical) not much bout shift motor on frnt axle , guessing works on vacume , so hopefully can make work.
blazer160 is offline
post #2 of 4 Old 08-29-2013, 10:03 AM
jp360cj
1977 CJ7
Yes it runs off vacuum. It can also be made to run off a cable.
I wonder I if its possible to use the solid shaft from the other D30? Then just seal the hole in the axle tube.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 4 Old 08-29-2013, 11:20 AM Thread Starter
blazer160
1990 XJ Cherokee
Awesome , did not evan think of that. Thankyou time for more research. Also have any idea how to hook up , if possible like to hook up using vacuum , or a cable ?
post #4 of 4 Old 08-30-2013, 09:54 AM
biffgnar
biffgnar's Avatar
This. XJ D30s into TJs is a common thing to do since they are HP. While people look for the newer ones that are not disconnect they can't always find them or find a better deal on a disconnect. You should be able to find plenty of write ups on it.
Romney in 2020!
biffgnar is offline
