Scout Dana 44 Questions - Page 2 - JeepForum.com
post #16 of 20 Old 12-28-2012, 04:46 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Another option would be to run CJ outers. Meaning the knuckles out, or even Chevy knuckles with CJ stubs, brakes, and spindles.
Mail crawling.
MisfitSeven is offline
post #17 of 20 Old 12-30-2012, 11:45 AM
foggybottombob
I used 79 Ford hubs and rotors on my front Scout D44 axle. You have to have Chevy/FSJ small bearing spindles to work with the Ford hubs and rotors. I know you can find those spindles on 73-76 Chevy K10s and 74-76 Waggys. I don't know if those spindles can be found in any other years. You can use Chevy/FSJ knuckles and calipers from any disk brake axle from the early 70's through the 80's at least. If you ever go SOA you will need flat top knuckles which come from the same year vehicles as the chevy small bearing spindles. Note that K20 trucks can have flat top knuckles but they will not have small bearing spindles.
foggybottombob is offline
post #18 of 20 Old 01-06-2013, 07:10 PM
BlueRubiconrich
yes 10 degrees caster that's with a 4" lift
yes?
I think I had to cut 1" from the front driveshaft
I run all CJ stuff brakes etc
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #19 of 20 Old 01-06-2013, 07:16 PM
kjonesie
1983 CJ7
My local 4x4 store found high steer knuckles for my 44 so I could use my 8 hole spindles. I mocked up my axle and set all my angles before I welded anything
kjonesie is offline
post #20 of 20 Old 01-17-2013, 07:22 PM Thread Starter
DYontheForum
1981 CJ7
What do you guys recommend for the front pinon angle, keep it close to the stock dana? Can I use my stock drive shaft?
DYontheForum is offline
