roll cage reinforcement - JeepForum.com
post #1 of 15 Old 01-26-2012, 04:43 AM Thread Starter
Budke
Ever since I rolled the YJ, beefing up the roll cage in my TJ has been on top of my list of stuff to do. I want to see your stock roll cage beefed up to give me some ideas. Also how you tie it into the frame if you do.
I'm not looking for full blown, built from scratch cages. Just a decent cage that was built from the stock cage.
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #2 of 15 Old 01-26-2012, 05:19 AM
Irongrave
AtoZ fab http://www.atozfabrication.com/store...rangler-s.html
blue torch fab http://www.bluetorchfab.com/Product/...-Cage-Kit.aspx
PSC http://shop.poisonspyder.com/TJ-LJ-T.../14-18-010.htm
I have and AtoZ cage in my YJ and my dad's TJ has a BTF cage
Current
2002 WJ 2wd DD
Irongrave is offline
post #3 of 15 Old 01-26-2012, 05:23 AM
little_Jeep
I added a Sport cage to mine...... I cut the factory base plates off, then welded on new base plates from Ballistic ("A", "B", & "C" pillars). I also added a frame tie in kit for the "A" and "C" pillars.
little_Jeep is offline
post #4 of 15 Old 01-26-2012, 07:16 PM
scubamc
Check out the cage thread in the fab section.
scubamc is offline
post #5 of 15 Old 02-01-2012, 09:35 AM
DualPurposeXJ
1994 XJ Cherokee
Here's a couple pics of my brothers cage. We built it off the stock B pillar, we would have kept the tubes coming off the B pillar but they appeared to be .90 wall so we replaced them with 1 3/4" .120 wall
If you're in control you're not going fast enough - parnelli jones
DualPurposeXJ is offline
post #6 of 15 Old 02-01-2012, 10:51 AM
fratis
fratis's Avatar
-insert meaningless out-of-place political diatribe-
fratis is offline
post #7 of 15 Old 02-01-2012, 11:17 AM
little_Jeep
Nice looking cage. You may have a dash bar that I just don't see, but if you don't, you might want to consider adding one then place a gusset in each corner (circled). At the top of your "A" pillar, you might want to triangulate this corner more as Jeeps tend to roll onto one windshield corner or the other which will push your cage sideways and cause the down tubes to fold sideways.
post #8 of 15 Old 02-01-2012, 02:16 PM
MO2500
You said you weren't looking for pics of full, built from scratch cages, but here are a few pics of my tie-ins that may help you.
A Pillar tie-ins
C-pillar tie-in
Instagram: @omsmike
MO2500 is offline
post #9 of 15 Old 02-01-2012, 02:19 PM
ytowntj
For the money, I dont think you can beat the BTF add on kit. I havent done one personally but will be getting one very soon. Its a great start and I will be adding on to id with some custom pieces as well as tying the A and Bpillars into the sliders and the frame. Genright, Poly performance, and KOZ also make very nice add ons.
http://www.genright.com/ProductInfo....ductid=GRC2002
http://www.polyperformance.com/shop/...t-p-20215.html
Not that poly is 500 not 200 for the front section-the drop down p/n is misleading
http://www.kozoffroad.com/pages_cata...jrollcages.htm
Very nice MO2500, Ill be doing something similar with mine, only I think Im going to sandwich my sliders in bewteen the tub and plate
Parting my TJ:
My build - Odd approach to 33's
ytowntj is offline
post #10 of 15 Old 02-01-2012, 05:10 PM
DualPurposeXJ
1994 XJ Cherokee
If you look closely in the first picture you can see the dash bar. Ya the cage is being built to race specs so basically every joint is going to be gusseted and there will be a W in the b pillar that cage isn't even close to being done.
post #11 of 15 Old 02-01-2012, 06:22 PM
little_Jeep
Never mind..... carry on.
post #12 of 15 Old 02-01-2012, 06:55 PM
DualPurposeXJ
1994 XJ Cherokee
[/B]
I guess I should have mentioned that in my first post
post #13 of 15 Old 02-01-2012, 10:55 PM
nitecop
I've got a Rock Hard brand bolt in cage in my 99 TJ. (no frame tie-ins)
http://www.rockhard4x4.com/category_s/56.htm
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #14 of 15 Old 02-04-2012, 06:27 PM
solman
Heres the BTF stort cage I installed in my TJ last week.
solman is offline
post #15 of 15 Old 05-08-2013, 09:16 AM
mrJ
2002 KJ Liberty
do the door uppers just weld into the rollbar and the brackets bolt into the windshield? we started on mine last night and couldn't figure out where the little oblong rectangle brackets go. and do you just put the dash reinforcement plates on after you weld in the lower windshield/dash bar for extra support or what?
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
cage rattles. how do I get rid of the rattles completely? guarnibl Advanced Jeep Tech 8 12-22-2011 06:51 PM
