Rear end question? - JeepForum.com
post #1 of 3 Old 05-06-2013, 12:57 PM Thread Starter
Midnightwolf
1990 XJ Cherokee
Rear end question?
I have a 90 XJ. My rear axle tubes came loose in the diff housing and the input shaft ended up pointing towards the stars and blew out the u- joint. I was driving on the street when this happened. Can anyone come up with an idea as to what caused it. Rear end did not lock up. all gears in the diff were fine. Brakes were all good too. I wasnt stompiing on the gas either just starting off from a stoplight when it happened.
Midnightwolf is offline
post #2 of 3 Old 05-06-2013, 02:13 PM
fratis
fratis's Avatar
the rosette welds failed. the majority of the damage itself was probably done at a previous time.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #3 of 3 Old 05-06-2013, 02:32 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it was probably previously hit hard or bent in some manner.
the gears and such may be "good" but you need a new axle anyways. may as well get something you want that's stronger.
ratmonkey is offline
