Question on setting up a 9" third member.. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Advanced Jeep Tech > Question on setting up a 9" third member..
Component speaker deal for your dash - NalinMFGIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSteering and more from Ruffstuff!
Unread 07-20-2014, 01:52 PM   #1
cjjon7
1983 CJ7
Im looking at getting a Strange 9" third from a guy, its new just several years old, but its got a spool in it along with 4.56's. If I were to remove the spool and ring gear, replacing it with a detroit and the same ring gear, would there be any need to mess with the pinion (ie re-shim it) or would it be fine to leave alone? I assume since the same ring gear thats currently set-up properly in it is going back in that I would be ok to just re-set the backlash.
Am I correct in saying so? Never messed with a 9 before.
-Jon
cjjon7 is offline   Reply With Quote
