pitman arm reamer - JeepForum.com
post #1 of 5 Old 12-21-2012, 01:08 AM Thread Starter
Ripper3494
pitman arm reamer
Just wondering what type of reamers you use to ream out a pitman arm. Can you just use a standard 7 degree tierod reamer?
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #2 of 5 Old 12-21-2012, 06:37 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
It's the same, just deeper for the high angle Chevy ends
ratmonkey is offline
post #3 of 5 Old 12-21-2012, 02:29 PM Thread Starter
Ripper3494
Im confused by its the same but deeper, is it just longer?
build thread:
RC vs BDS
post #4 of 5 Old 12-22-2012, 08:37 AM
89yjsahara258
You just ream it further. The taper degrees stay the same but the two holes get proportionally larger.
About the only places I haven't used it are the small mini steel skid I weld onto control arm mounts and that is because I broke my steel to aluminum welder and it costs too much to fix it.
89yjsahara258 is offline
post #5 of 5 Old 01-27-2013, 10:10 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
There are two common tapers for domestic TREs. One is 1.5" per foot taper and the other is 2". Neither is 7. 1.5" per foot is slightly over 7, so the commonly used Snap-on reamer isn't quite accurate.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
