Pitman arm help - JeepForum.com
post #1 of 12 Old 12-25-2012, 09:49 PM Thread Starter
czjeeper
Yj Pitman arm help
'92 YJ, SUA BDS 3.5" springs, '78 F250 HP Dana 44, narrowed to Grand Wagoneer width.
Using '78 F150 knuckles.
Ruffstuff GM 1 ton "y" steering kit.
What pitman arm do I run? waggy, ford, yj?
This is a daily driver, so keeping good steering is a must!
I tried searching, but nothing came up with my situation.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 12 Old 12-26-2012, 12:02 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The length of the sector shaft to drag link end on the standard yj/tj/zj/xj/mj pitman arm is 5.5"
The d30 has a steering angle of 42 or 43 and the Ford hp44 is 45 I think.
If you were changing steering boxes there's steering angle there to consider, but with the angles the d44 & 30 can do it's pretty much a simple ratio.
Measure ball joint center to tie rod end center on both axles.
New pitman length will be yj pitman length divided by d30 ball joint length then multiplied by d44 ball joint length.
The wj is 6.25 or 6.5" and the waggy is close to 6.75" I think.
Though I'd check Mr n's site and pirate on that.
I've got btf arms and have had to make a custom arm, I used a100 3/4" plate.
Err on the side of slightly too long on the arm compared to what you really need if buyinga stock arm. Hitting the knuckle steering stop is better than bottoming out the piston in the gear box.
ratmonkey is offline
post #3 of 12 Old 12-26-2012, 07:34 PM Thread Starter
czjeeper
Cool, so I've got some measurements to take.
Also, if I use the Wagoneer pitman arm, do I get a drop pitman arm? 4" SUA lift.
US Army combat vet
czjeeper is offline
post #4 of 12 Old 12-26-2012, 08:46 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
I noticed that when I went to a longer pitman arm, it was easier to bind my tires against an obstacle and have no steering. This was with a flattened drop pitman arm. With the longer arm I was able to take advantage of more turning radius, but it did feel like the tires gave a lot more input to he steering wheel rather than with a TJ pitman arm on my TJ.
Mail crawling.
MisfitSeven is offline
post #5 of 12 Old 12-26-2012, 08:52 PM Thread Starter
czjeeper
Yj
So, a flattened drop pitman arm...you flattened it?
Would you recommend a dropped waggy arm or a flat arm?
US Army combat vet
czjeeper is offline
post #6 of 12 Old 12-26-2012, 09:11 PM
MisfitSeven
MAiL Crawler.
Will you be running Heim joints? I can't say what will work with your setup. I had a stack of pitman arms that I kept playing with until I found which worked better with my new front axle. I am now running a WJ pitman arm with the TRE above the arm.
Yes, I took a drop pitman arm, cut where the bends were, then pressed it flatter. It's not completely flat, more like a stock arm just longer. I achieved the same 1.5-2" drop like stock. Then welded up the V notches, and around he other side for strength. It turned out really nice actually, and it failing has never crossed my mind.
Mail crawling.
post #7 of 12 Old 12-27-2012, 10:58 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Going with a larger bore box like a psc unit or the Durango box would get your leverage back. Or get some hydro assist going.
post #8 of 12 Old 01-08-2013, 07:56 PM Thread Starter
czjeeper
Okay, I measured the ball joint to TRE hole and I've got about 7" center to center on my F150 knuckles.
I'm guessing I want a waggy drop arm...
Any preference with any of these?:
http://www.wfoconcepts.com/pr/Superl...3163/3360/3362
http://www.wfoconcepts.com/pr/Superl...3163/3360/3361
http://4x4.fatbobsgarage.com/rough-c...kee-p6462.aspx
http://www.bjsoffroad.com/prod-465.htm
US Army combat vet
czjeeper is offline
post #9 of 12 Old 01-08-2013, 09:01 PM Thread Starter
czjeeper
I don't know why I never read this before, but the CJ arms are 7"?
US Army combat vet
czjeeper is offline
post #10 of 12 Old 01-08-2013, 09:41 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
watch out, the sector shaft on the manual box is smaller spline count than the power steering box.
post #11 of 12 Old 01-08-2013, 10:57 PM Thread Starter
czjeeper
Yj
Thanks!
I just don't know if I should get a factory or dropped arm!
US Army combat vet
czjeeper is offline
post #12 of 12 Old 01-09-2013, 05:50 AM
MisfitSeven
MAiL Crawler.
This might help.
chevy van
TJ
WJ
Wagoneer
Mail crawling.
