Oil pressure sending unit - JeepForum.com
post #1 of 9 Old 08-02-2013, 01:41 PM Thread Starter
Elrod90xj
1990 XJ Cherokee
90 xj oil pressure sending unit help
So i was reading on some forums on here and alot of people say that their oil pressure sending unit was leaking oil. So i went to check mine out, it had a little oil on it but the wire coming out was hanging there not connected to anything! I looked all around the area and could not find any other disconnected wires. Does anybody know where the wire goes to from the unit? i was having problems with my oil gauge, and I think i might have found the problem. Now if i can just figure out where the wire needs to be reconnected I will be golden. Thanks!
Elrod90xj is offline
post #2 of 9 Old 08-03-2013, 10:54 AM
19Mike95
Just follow the wire you'll always find out where it goes
19Mike95 is offline
post #3 of 9 Old 08-04-2013, 01:02 AM Thread Starter
Elrod90xj
1990 XJ Cherokee
The wire is connected to the unit, and is about a foot long at the end is a splicer that is disconnected so the wire just ends. My problem is that I can't find the other end that it came off of it. Is it just one wire running from the gauge to the unit? If so I should be able to just run a new wire from the gauge to the unit, right?
post #4 of 9 Old 08-04-2013, 01:16 AM
19Mike95
The rubber booted end is unplugged? Lemme go look at mine real quick ill let u know where it's supposed to go unless mines messed up to lol
19Mike95 is offline
post #5 of 9 Old 08-04-2013, 01:26 AM
19Mike95
I don't know what color wire yours may be but mine is yellow/black and goes to the harness than branches off from there one runs up along the valve cover to the battery one runs under the tub I'm assuming it goes into gauge on your dash
19Mike95 is offline
post #6 of 9 Old 08-04-2013, 01:52 AM Thread Starter
Elrod90xj
1990 XJ Cherokee
The rubber booted end is plugged into the unit and has one wire coming out that is not connected to anything.
post #7 of 9 Old 08-04-2013, 01:56 AM Thread Starter
Elrod90xj
1990 XJ Cherokee
Also the wire coming out of the unit is blue, and I don't have any wires runningalong the valve cover, all the wire looms are running between the battery and overflow tank. Mines a 1990 so maybe it's different
post #8 of 9 Old 08-04-2013, 01:58 AM
19Mike95
But the harness also y s off to under the firewall
19Mike95 is offline
post #9 of 9 Old 08-04-2013, 02:01 AM
19Mike95
I could also be wrong so best bet go to your local parts store they should print off a diagram which would show you exactly where it goes.
19Mike95 is offline
