NP205 to stock shifter linkage - JeepForum.com
post #1 of 5 Old 02-14-2012, 02:21 AM Thread Starter
JohnnyBallistic
I am seeking advice on finding a shift linkage. First Here is the lay out. 1997 TJ with Ford 302 married C6 transmission, to an NP205 transfer case (solid set up). The issue is I am looking for a shift linkage to use the stock shifter to operate the NP205. Any ideas, information, or know adapters? I checked Novak and Advanced. I can't find anything that links the stock shifter to the transfer case.
JohnnyBallistic is offline
post #2 of 5 Old 02-14-2012, 10:02 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
you'd have to build it.
frankly i'd ditch the stock shifter for a cable operated unit in a heart beat.
ratmonkey is offline
post #3 of 5 Old 02-15-2012, 11:24 AM Thread Starter
JohnnyBallistic
It has a cable operated shift for the transmission. I need a linkage for the transfer case.
post #4 of 5 Old 02-15-2012, 11:39 AM
Ripper3494
just out of curiosity why do you need a linkage? i run cables on both my trans and t case and its great
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #5 of 5 Old 02-17-2012, 09:18 AM
BossCherokee
1985 XJ Cherokee
I agree w Ripper, cable, especially for a framed vehicle, in my opinion is the way to go. My 1st conversion 2 to 4wd was in 1985. I've done both linkage and recently I did cable on one of my XJ's. No worries about flex binding or clearances. I used aircraft braided stainless with wire wrapped cables that have zero fittings for greasing at each end. I got them from a aircraft surplus house 3 of them for $27.00. They are about 3ft long and glad I did! I have 3 sticks and they all shift smother than linkage!!
BossCherokee is offline
Opinions on Transfer Case Shift Linkage Idea WhyJayPA Advanced Jeep Tech 9 04-22-2012 10:13 AM
