New fuel pressure regulator running high 40 to 50 psi - JeepForum.com
post #1 of 8 Old 12-20-2012, 12:46 PM Thread Starter
tequilamike
Can i expect any problems?
Will this cause anyissues
It is new and measures 40 at idle and 50 psi with the vacume line unplugged.
I am running a stroker so some extra fuel is needed.
4.5 stroker in a 91 yj. with 24# injectors. mild cam. hi flow everything, borla header, 1 range cooler spark plugs, msd high energy stock replacement coil and larger wires 7mm i think. No sensor mods.
Any help would be very appriciated.
M
tequilamike is offline
post #2 of 8 Old 12-26-2012, 07:59 AM
hotrod351
1955 M-38
i thought 40 - 50 was stock fuel pressure for injected engines. what doe your jeep call for.
hotrod351 is offline
post #3 of 8 Old 12-27-2012, 10:08 AM Thread Starter
tequilamike
Thanks for the reply.
Stock is 31 to 39 psi
M
post #4 of 8 Old 01-03-2013, 11:08 AM
foggybottombob
I have a 4.6 liter stroker in my XJ and your regulator is a bit high pressure. I got an adjustable regulator from Hesco for mine.
foggybottombob is offline
post #5 of 8 Old 01-04-2013, 09:19 AM Thread Starter
tequilamike
Thanks
I guess i wont worry about it.
I suspect it won't cause any problems.
The adjustable ones are expensive???
post #6 of 8 Old 01-04-2013, 09:37 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
If you are looking for stock pressure, can't you just get a replacement stock regulator?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #7 of 8 Old 01-07-2013, 04:09 PM
foggybottombob
Stock pressure is not enough for 24 lb/hr injectors and 4.6 liter displacement. Your engine will be running rich with the setup you have now.
post #8 of 8 Old 01-07-2013, 04:56 PM Thread Starter
tequilamike
Running lean
I am running a stroker 4.5L so i need a little more pressure.
It was ordered as a stock regulator.
I think i need about 3 to 5 more psi than stock, and now have 5 over what i think i need.
I would think the o2 sensor would shorten the injector cycle to make 14. 7 AFR.
Also i am lean now 14.5 to 15.1 WOT
Which is another reason i am trying to get more fuel into it.
Running out of options.
Been thinking about an o2 sensor adjuster.
My nox is around 375ppm.
It was 513 before i put in a clooler plug to pass smog.
Might try a wider gap on my plug to retard timing a bit.
Might have that one backwards.
Thanks for your input.
M
