Need Help Choosing Injectors for 2.4 Turbo Wrangler - JeepForum.com
post #1 of 5 Old 11-13-2012, 08:36 PM Thread Starter
MO1535M
I hope this is advanced jeep tech enough...
I was following a few thread on turbo 2.4's such as Air Sierra's, CrisSmith..'s etc. but they were only pushing 6 psi of boost. Air Sierra's worked without any Fuel management or computer changes. Air Sierra stated that the stock computer was able to compensate up to 10-12psi of boost. I am going to attempt that 10-12 psi of boost. I'm doing a front mount air/air intercooler and flipping turbo upwards like Air Sierra.
My question is... what size injectors (at stock 49psi) do I need for the 10-12psi intended? Air sierra used 27lb injectors but only boosted to 6psi. Part number he used was 1W7EAA from fiveomotorsports.com
I appreciate any and all help. No bashing on the poor little 2.4, please. I am eventually doing an LS swap but want to make due with what I have for now, so again, no comments on that, please. Thank you.
If it matters... I will be in altitudes ranging from -50 to 50 feet sea level.
Again, thank you.
MO1535M is offline
post #2 of 5 Old 11-13-2012, 08:46 PM Thread Starter
MO1535M
I used an online calculator and got 33 to 36 lbs/hr... sound about right?
MO1535M is offline
post #3 of 5 Old 11-17-2012, 02:26 PM
bridger04
1980 CJ7
Did you purchase your air-air int. new or you pick from the jy
Curious what you fabbed to mount it and how much room?
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Abraham Lincoln
bridger04 is offline
post #4 of 5 Old 11-18-2012, 09:33 AM
aTX427
Can the stock fuel pump handle the additional delivery requirements?
aTX427 is offline
post #5 of 5 Old 11-19-2012, 10:46 AM Thread Starter
MO1535M
I bought it but haven't installed it, I may need to make spacers to push radiator back a bit. Waiting on correct injector size to go ahead with install.
Stick fuel pump can handle the ls2 swaps.
MO1535M is offline
