need engine swap help! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Advanced Jeep Tech > need engine swap help!
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and C
Unread 04-02-2014, 10:37 PM   #1
strvger01
1966 CJ5
i'm posting this on a couple of forums as i need to get the swap done.
i'm helping a buddy (as i'm no mechanic) swap a 1981 cj 2.5L into my 1966 cj5a. used the novak kit and have the engine, tranny, and tc all bolted up together. it's just not fitting and we can't figure out why. it's all the way to the right as far as it cn go without hitting the frame and the bell housing still won't clear the brake pedal and linkage. i don't remember seeing this problem on the sbc swaps i've checked out in the forums, so why this little 4 banger?
any help will be greatly appreciated.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2014, 07:54 AM   #2
jp360cj
1977 CJ7
This is just a SWAG as I've never messed with that style brake linkage, but can you disconnect it, slide the engine/trans in, then reconnect?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline   Reply With Quote Quick reply to this message
Unread 04-08-2014, 10:39 AM   #3
strvger01
1966 CJ5
no. the bell still makes contact at the correct mounting location for the engine and tranny. first will be pulling the heater. then i'll be switching to swing down style pedal and going with a hydraulic clutch. moving all that over a few inches should solve the problem.
