measuring for rear driveshaft xj to yj - JeepForum.com
post #1 of 6 Old 03-02-2013, 07:51 PM Thread Starter
weeds94yj
i am in the process of doing a frame restoration and putting a 350/700r4/np231c in my 94 yj my first question is dose the np231c use the same u joint as the 231j and also when im cutting and rewelding my xj driveshaft do were do i want the slip to be when it is installed on the jeep in the middle or closer to the top or bottom thanks.
weeds94yj is offline
post #2 of 6 Old 03-03-2013, 05:27 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I have done several XJ shaft shortening mods for use in a YJ. I like to do them so that there's ~1" of compression left when the Jeep sits statically with the weight on it and the pinion is dialed correctly.
Joe Dillard is offline
post #3 of 6 Old 03-03-2013, 08:40 PM Thread Starter
weeds94yj
okay thanks that is what i was looking for and these driveshafts will work fine with a four inch lift right?
post #4 of 6 Old 03-03-2013, 10:32 PM
Joe Dillard
Yep, there seem to be enough (what's that word I'm looking for?) play in them in a 4" YJ suspension lift to allow for the suspension to droop & the ujoints not bind.
post #5 of 6 Old 03-04-2013, 12:38 PM
PA_YJ19
I was wondering how other people did it, I did 1 1/2" of compression left so it had the same amount compressed as extended. I really had no idea what was correct tho. I haven't had ne issues with it yet . I have another one I'm going to weld up for my spare so I guess ill do it at 1" compressed n so how it works. Never hurts to ask I guess, like the OP.
PA_YJ19 is offline
post #6 of 6 Old 03-04-2013, 08:14 PM Thread Starter
weeds94yj
i thought i read there was four inches of play in the slip
