LQ4 to 700r4 - JeepForum.com
post #1 of 5 Old 04-09-2012, 10:04 AM Thread Starter
koesdibyo
LQ4 to 700r4
I know Ive read it in the past, but my old computer crashed and all my saved links are gone.
I have a 1999 LQ4 - the one with the long crank, and Im going with the 700r4/np241C for my swap. Im trying to recall what I need/need to do to make it work.
I remember that the alum head lq4s (short crank) needed a spacer and a certain flywheel, etc etc.... but the long crank wasnt as desirable.
I dont want to go the route of a custom torque converter, and im positive there was a solution to mating these together.
koesdibyo is offline
post #2 of 5 Old 04-09-2012, 11:43 AM
Ripper3494
i have a little different set uup than you but for the torque converter i just drilled the 3 holes out a little bit and it bolted down fine
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3 of 5 Old 04-10-2012, 08:08 AM Thread Starter
koesdibyo
and yours is the long crank lq4? I know the 4l60e and 700r4 are essentially the same aside from the electronics.
post #4 of 5 Old 04-10-2012, 07:12 PM
1 ton yj
1 ton yj's Avatar
Same here, 6.0 to 700R4.
If the engine came in front of a 4L80E, it has the dished flexplate and all you need to do is egg out the converter holes with a die grinder. If it came in front of a 4L60E you need the spacer with an older flat flexplate.
Either way the bellhousing inspection cover won't fit however. No big deal.
1 ton yj is offline
post #5 of 5 Old 04-11-2012, 08:07 AM
badbird17x
badbird17x's Avatar
1994 ZJ
Pretty sure they all need the $40 bushing from jegs for centering the converter. Other than that I just opened up the flex plate bolts and bolted the 350 converter right on.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
