Lets rehash the Dana 70 vs 14 bolt topic. - JeepForum.com
post #1 of 71 Old 02-19-2013, 08:15 PM Thread Starter
TJRHD
I was just curious if the support for the 70 has gotten better over the years. It seems the 70 has quite a bit more clearance but the 14 bolts are plentiful and it is easy to find spare parts for.
NOT A HATER
TJRHD is offline
post #2 of 71 Old 02-20-2013, 07:02 AM
Bama_WJ
Bama_WJ's Avatar
I'd throw the Sterling 10.25/10.5 into that mix as well...
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #3 of 71 Old 02-20-2013, 07:36 AM
-jb-
What do you want to know? The 14bolt, 70, and 10.25 are all GREAT Axles to grab. Each with their own little advantages over the other. The 14bolt can be fixed with a shave of the lip or a shave kit
http://www.ballisticfabrication.com/...it_p_1728.html
http://www.tmrcustoms.com/store/inde...oducts_id=1286
14 bolt also has the pinion support like a Ford 9in does to help fix pinion deflection. 14 bolt WMS can be changed from a simple hub swap and this axle is the most popular for cheapness and aftermarket support
The dana 70 looks almost like a dana 60 except a tad bigger housing and thicker tubes. They were made in all types of configurations in all types of vehicles. From the smooth bottom 70-U to the 4in thick tubed 70-HD. I have two 70-B's that are 35spline shafts. Aftermarket support is growing with these axles.
The 10.25 is another great axle with good ground clearance and has good support for as well.
So take your pick. I prefer a 70 or 10.25 over a 14 because of ground clearance issues and just the fact it's something different. Plus most people will think I'm running a dana 60 and wonder how I'm not breaking it on 40in tires
Yellow Jeep Member #42
01 TJ Sport
00 TJ Sport
-jb- is offline
post #4 of 71 Old 02-20-2013, 07:52 PM Thread Starter
TJRHD
Thanks! I am checking all of this out. Someone told me the dodge d70's brakes hang too low so they have to be modified. 14bolts are really easy to find here. I was looking at the 70's because of the more clearance and more gear options but I guess if as low as you can go on a 60 is 5.38 then that isn't a good point to look at.
NOT A HATER
TJRHD is offline
post #5 of 71 Old 02-20-2013, 07:53 PM Thread Starter
TJRHD
If I got a 35 spline d70 and was able to get some extra shafts that would be the best probably.
NOT A HATER
TJRHD is offline
post #6 of 71 Old 02-21-2013, 02:16 AM
jason m
Nothing but the facts
jason m's Avatar
Other than the front pinion on the 14 bolt being worlds stronger than the 70 and 10.25, I would have allways put them in the same boat.
You really cant go wrong with any of them with a 39" tire, start getting around a 42" then I would say the 14 bolt will step forward as the 70 "could" start snapping front pinions off, they are they same 29 spline pinion as a 60.
Ive said this a ton of times on this forum, my shaved 14 bolt had more clearance than my front HP 60, it was only a 1/4" more but still had more than the unshaved 60 front. All I did was knock the lower lips off and let the rocks do the rest.
Served me very well for 7 hard years, replaced it for a 60 steering axle. Time will tell if I get the same out of that axle.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #7 of 71 Old 02-21-2013, 06:19 AM Thread Starter
TJRHD
Jason.
So you didn't do a shave where you had to get into the pumpkin housing? It is hard to beat a 14, they are so easy to find.
NOT A HATER
TJRHD is offline
post #8 of 71 Old 02-21-2013, 05:40 PM
jason m
jason m's Avatar
Nope, I built that axle well over 8 years now and ran it hard for at least 7. Now that axle has found its way under a KOH car and has yet to run but I dought it will let the new onwer ( my good friend ) down.
Again no I didn't touch anything in the housing other than shaving the lips down and even then after a few years I wish I hadn't even really shaved those.
Why you ask well years of sliding and grinding over rocks they really ground down the under belly of the housing along with the ruffstuff cover. I got thin under there and once the axle was pulled for the other rig I built it back up with weld, was tempted to hard face it lol.
You cant go wrond with any of the axles posted, my vote of course would be the 14 bolt, I know what they can take pulled right out of a factory truck and just put into use.
Weld the tubes and the gears call it good. A bomb proof axle that will last till 44" tires in stock form.
I wedge my rear axle bad one day, lifted that rock off the ground buy at least a foot. Under a slow thorttle I could pop the front tires off the ground, was kinda cool.
But we had to get me out, I could not go backwards, oil pan on a rock would have torn it right out. Only way was forward, so I hammerd the thorrtle not easying into like I was doing a few minutes before.
The hole jeep lifted on that one side axle, felt it tork to the right and it poped free with a loud bang, figured I blew that side axle it was its time to go.
Got home pulled the shaft, to my supprise it looked as good as the day it got installed.
Only pic I have of me stuck, but it was bad.
Point to story, any of the other axles posted here in this thread I would have busted the input shaft, i think at least. But the 14 b took it, the axle was probally very close to its yeild point of failure, but it didn't.
I'm not telling you what to run, thats your choice. I'm telling you what worked for me for years with no and i mean no exspensive upgrades.
Jason.
jason m is offline
post #9 of 71 Old 02-24-2013, 05:02 PM Thread Starter
TJRHD
Thanks for the replies, I keep going back to the 14 bolt regardless of its clearance because of all the reasons stated. I am kinda wanting a 70 because of the extra clearance and it is different than most have around here. I kinda like to be different . I do not have any experiences with the chrysler axle simply because noone has them around here at all! I guess I will have to see which deal is best when I come across it.
NOT A HATER
TJRHD is offline
post #10 of 71 Old 03-05-2013, 01:42 PM
OzarksYJ
Listen to Jason,
I also have 14, shave the lip and get a cover from Barnes, Crane, etc., or contact TMR and do a full shave which will net @ 2"+ gain. If you're going to do 37"-40 tires there is no reason to do anything else and be nearly as cost efficient.
OzarksYJ is offline
post #11 of 71 Old 03-05-2013, 02:04 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
I've got the 14 bolt in my new rig and I love it. I ran 44x21" boggers on a 91 Suburban mud truck several years ago and it held up with all factory stock internals... I love the 14 bolt! I might run an Eaton HO72 if I could find one for a good deal though... just saying...
Necromancer_tat is online now
post #12 of 71 Old 03-05-2013, 05:06 PM Thread Starter
TJRHD
I am going with a 14 bolt but there is a great possiblility that a d70u just fell into my lap.
NOT A HATER
TJRHD is offline
post #13 of 71 Old 03-05-2013, 05:12 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
What are you going to run for a front axle? Have you started a build thread?
Mail crawling.
MisfitSeven is offline
post #14 of 71 Old 03-05-2013, 05:15 PM Thread Starter
TJRHD
HP D60, I am just gathering parts now. I am still wheeling this thing on my stockers.
NOT A HATER
TJRHD is offline
post #15 of 71 Old 03-05-2013, 08:18 PM
MisfitSeven
MAiL Crawler.
Cool. Going to stick with the NP231? Build thread yet?
Mail crawling.
