Keeping the front end "down"/hill climbs/Instant Center... - Page 8 - JeepForum.com
post #106 of 119 Old 12-23-2011, 09:02 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by ftgiles View Post
Pretty sure he means "twist" not wrap.
The length of the arms and their pivot point relationship causes the axle to either twist or not. You want the front axle to twist as it moves through the arc of the control arms because that maintains a constant caster angle.
In case folks don't understand the importance of that for some rigs, when you build custom steering, trackbar, blah blah blah, real estate for places to get mounted and live becomes very precious. Sometimes the tolerances are less than 1/8" between moving parts. If you get any or a lot of caster change, the tilt of the axle as it moves through the range of motion can cause stuff to crash into each other.
The down side is you wind up with a parallel 4 link or equivalent which isn't always the best geometry, but it preserves the close tolerances. Another downside is the pinion angle doesn't change, so it can run the pinion yoke into the rocks at full articulation driver's side down if you don't pay attention.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #107 of 119 Old 12-25-2011, 10:58 PM
Hussler
1992 XJ Cherokee
The length of the arms and their pivot point relationship causes the axle to either twist or not. You want the front axle to twist as it moves through the arc of the control arms because that maintains a constant caster angle. Or maybe in the rear you don't want a twist so that you maintain a constant pinion angle.
No, wrap. By making the lower link in line with the axles centerpoint I was thinking it would make the axle would lose some of its ability to hold proper caster under load. Like, it would want to rotate forward.
Enlighten me please.
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #108 of 119 Old 12-26-2011, 01:10 AM
ftgiles
You're right. If you decrease the separation of the ca's on the axle, then there is less leverage available to control wrap. Less separation requires bigger joints and stronger mounts. More separation allows you to run smaller components.
ftgiles is offline
post #109 of 119 Old 12-27-2011, 10:45 AM
Imped
Imped's Avatar
I run 8" of vertical separation at the axle with 2.5" JJ's all around. Again, zero movement. The axle can't roll one way or the other because the control arms won't let it.
OlllllllO
IndyORV
Imped is offline
post #110 of 119 Old 12-27-2011, 07:37 PM
Hussler
1992 XJ Cherokee
I was looking at your truss, did you move your upper control arm mounts higher than stock to make up for separation? Did you move the upper control arm mounts (axle end) towards the rear of the jeep?
Hussler is offline
post #111 of 119 Old 12-27-2011, 09:51 PM
Imped
Imped's Avatar
Yes, they are higher than stock. The only way to get them as low as stock (or even close) is to not run them on top of a truss (above the diff). You'd have to run them beside the diff.....just like stock. All else being equal, if I ran them that way my AS would be very low (unless I moved the joint at the frame upper mount down) and the separation would be pathetic....like 6" and 4". And yes, they are moved back. You need to remember that my pinion is quite a bit higher than stock, which rolls the upper mounts back. No, it really doesn't matter at all.
OlllllllO
IndyORV
Imped is offline
post #112 of 119 Old 01-03-2012, 06:52 PM Thread Starter
RaggedOleMan
(Image above is with the 1-1/4" pucks removed)
(Image above includes the 1-1/4" pucks)
I modified the top illustration to reflect the removal of the 1-1/4" pucks, leaving the OME 2-1/2" + 1/4" spring isolators. The numbers that result are better, though far from the ideal, as I understand it.
If I use IMPED's cog, the results improve slightly, in my case. The Anti Squat numbers in the image that are associated with IMPED's COG are in "blue" and are = to 242% as opposed to the 251% with the pucks. If the ideal % is around 100%, then my set up is, for the sake of this discussion, friggin' horrible.
Seems to me that the stock control arm mount locations are only really suitable for stock tires and stock lift/height. Once lifted, in this case with the OME 2-1/2" lift, and 33" tires the end results bring on the suck...relative to IC and this discussion.
Am I beginning to understand this correctly?
RaggedOleMan is offline
post #113 of 119 Old 01-03-2012, 09:05 PM
ftgiles
Two big red stars!!
But as you know, there is a lot more to it besides IC's. And the suck isn't really that bad for 2" of lift. The suck is really at 4" of lift and stock control arm frame mount locations.
ftgiles is offline
post #114 of 119 Old 01-23-2012, 12:07 PM
flip2spin
Two big red stars!!
great thread
flip2spin is offline
post #115 of 119 Old 01-29-2012, 12:54 PM
Timido
Good reading. What is good for roll axis height for street trail Rig. Right now I have 85% Anti squat on the top hole and %105 on the middle hole with 2deg roll axis angle and 27" roll center height.
My 4link number links
http://farm8.staticflickr.com/7019/6...79e0b37a_b.jpg
http://farm8.staticflickr.com/7030/6...b6e530ed_b.jpg
Timido is offline
post #116 of 119 Old 01-29-2012, 02:00 PM
pcoplin
pcoplin's Avatar
In my (limited) experience, the flatter the roll axis the better. 2 degrees is good, and I would run at the 85% hole. Your lower triangulating is keeping that roll axis low. The farther out towards parallel you get the steeper it will become. But really, get out and drive/wheel it on both settings and go with whichever feels better.
pcoplin is offline
post #117 of 119 Old 04-10-2013, 01:22 AM
aTX427
Found a decent read on instant center, roll center and roll steer.
http://www.sporttruck.com/techarticl...nt_center.html
aTX427 is offline
post #118 of 119 Old 04-11-2013, 12:08 AM
Kodiak17
Love this thread.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #119 of 119 Old 07-06-2015, 01:55 PM
VladoTJ
Tj Conclusion
Nice tread. I was really interested in doing some little modification to my current 3.5 inch short arm lift with 33-35s to get better close stock results with both track bars and short arms(not changing them) and current height of 3.5 inch. Learned in Imped`s Suspension geometry link it is a labour.
If I am correct this is possible when I clear lower axle mounts( not down but behid the axle tube as Imped did) then put uppers at the axle higher to keep stock or 8 inch separation. Than cut frame lower mount and weld on some nicer mounts from Artec bit backwards 1/2 inch max 1inch due to axle lower mounts they shift a 1/2 inch backwards and maybe relocate upper frame mount to get stock separation or 6 inch separation. This action shoud make the uppers and lowers significantly fatter. All pivot points will be almost or completely the same as a stock the only major change will be at the axle. Mounts will be higher to the axle tube center. I measured that 1 maybe 1.5 inch higher. And minor change at the frame just to get proper separation.
All this changes are pointed to get the arms close to stock set up and keep adj. track bars in the stock position with 3.5 inch of lift.
NOW there are a few guys who were interesting in this set up like me as I can not do drastic changes and drive it DD because of law here in my country.
Please enlighted guys check this set up if it can really work. Thanx Vlado
VladoTJ is offline
The new JK have "Hill start assist" Slenny JK Wrangler Technical Forum 73 08-30-2012 03:50 PM
Can the "Hill Start Assist" be disabled brtzworld1 JK Wrangler Technical Forum 1 07-01-2010 09:48 AM
Front axle is off center by 1/8" Apex TJ Wrangler Technical Forum 11 03-25-2010 09:43 AM
4 HI or 4 LO - Hill Climbs and Mud Runs (w Decent Amount of Wheel Spin) czar97 TJ Wrangler Technical Forum 7 09-05-2009 10:38 PM
Keeping JK "On Road" JillTheThrill JK Wrangler Technical Forum 45 01-24-2009 01:52 PM
