Just another 97 TJ, 5.3, 4l60E swap from 02 Tahoe - Page 4 - JeepForum.com
post #46 of 87 Old 03-08-2013, 11:17 AM
Sundowner
Originally Posted by bronco2guy View Post
What did you do? I plan to just run my stock pump for now, sicne heard it will work ok, just to get it running until i decide how I want to finalize the setup. I don't want an external pump.
If you change things out, I'd like to see what you end up doing with the sending unit; I'm eventually swapping to an external pump and filter, but I'm maintaining the factory sender.
Sundowner is offline
post #47 of 87 Old 03-08-2013, 12:29 PM
Robert0069
by passed the old regulator and ran the vett filter/ regulator
Robert0069 is offline
post #48 of 87 Old 03-09-2013, 01:02 AM
straightsixjeep
Sub'd, you dont see many v8 tj's. Looking forward to your progress.
straightsixjeep is offline
post #49 of 87 Old 03-12-2013, 08:24 PM
TJRHD
I am fixing to go through this myself, thanks for posting. I may be asking many questions.
NOT A HATER
TJRHD is offline
post #50 of 87 Old 03-12-2013, 08:47 PM
Robert0069
Bronco did you get your rad ?? love to see a pic and if you can hone in on the trans cooler area
post #51 of 87 Old 03-13-2013, 08:35 AM Thread Starter
bronco2guy
I did get radiator I took it out of box and put it back in box since I'm not ready yet..
My initial thought was rad seems very nice, but the L channel used for mounting to Jeep seems kinda thin??? I guess just have to see how it holds up.
Pace has been slow going, side tracked with surprise vacation trip for my Birthday.
I also sold a 79 Dana 60 I had, but over weekend bought a complete 86F350 single wheel truck, for the front.. I think i want to narrow pass side so I get 64in witdh.
I possibly have a guy coming to buy my 8.8 from jeep, wish I wouldnt have thrown away myd35, gunna be hard to move around.
Trying to get ahold of a guy about a 14 bolt thats from C C truck I think they are 63-64 wide..
bronco2guy is offline
post #52 of 87 Old 03-13-2013, 08:55 PM Thread Starter
bronco2guy
Saturday had to releave the itch so I took my explorer out, put the tires off the Jeep on it.
14 bolt from Cab Chassis I bought tonight 63in wide
post #53 of 87 Old 03-14-2013, 12:32 AM
straightsixjeep
MMmmmm 14 bolt. Nice pic wheeling, looks like a lot of fun.
post #54 of 87 Old 03-14-2013, 03:17 AM
rda616
What size tires are you planning to run? The 14bff seems a bit much for anything under 38". Especially if you already have an 8.8. Are you planning a stretch and big rubber too? That just seems like a lot of ground clearance lost and weight added otherwise!
rda616 is offline
post #55 of 87 Old 03-14-2013, 06:30 AM Thread Starter
bronco2guy
I will eventually shave the 14 bolt, it likely is more beef than I need for now. I'm also not to happy with the rear factory style shortarm setup. I want to go 4 link and get rid of the track bar. So would be better to sell the 8.8 setup for TJ than cut all stuff off. Then cost is a factor, I'm going to run a Dana 60 front and cheaper to just stay on 8 lug, I already planned on having to buy wheels cause I was going to run a D44 and need 5 on 5.5. If I would have kept 8.8 either need adapters $100 or C Clip eliminator kit $500. to get Big 5, but then LOL the 60 would cost me a bunch to get down to 5 lug. So I figured would be cheaper in the long run, eventually I will likley put some big meats on it. Just not from the start, but that could change.
Hoping tonight to weld in my engine mounts, I messed with them last nightfor awhile till my 14 bolt showed up, guy delivered it to me!! Can't beat that.
post #56 of 87 Old 03-14-2013, 06:32 AM
TJRHD
What did the 14 cost in your area? I found a late model srw with disc brakes already on it for 250.
NOT A HATER
TJRHD is offline
post #57 of 87 Old 03-14-2013, 10:31 AM Thread Starter
bronco2guy
It was 200. A little on the high side??, but I paid the guy little extra and he delivered to me, which saved me alot of time hunting one down, Plus has new bearings and all cleaned up allready.
I think you can buy a regular SRW one for cheaper, but just depends.
post #58 of 87 Old 03-21-2013, 10:59 AM Thread Starter
bronco2guy
Slow going, but finally making little progress.
Picking up a new welder tonight. This has been the major hold back once I moved to working back in my garage.
I also sold my 8.8 I have everything coming to 4 link my rear 14 bolt. I have most of the stuff coming to 3 link my 60 in front. My timeframes have been way pushed back. Trying to go ahead and build it up quite a bit.
post #59 of 87 Old 03-29-2013, 08:17 AM Thread Starter
bronco2guy
Some parts arrived yesterday!!!
post #60 of 87 Old 03-29-2013, 08:22 AM
TJRHD
Nice man!
NOT A HATER
TJRHD is offline
