Jeep CJ7 rear disc brake setup help - JeepForum.com
post #1 of 8 Old 03-20-2013, 09:45 PM Thread Starter
jarcher401
I am having trouble with my brake setup. I am using Isuzu Dana 44 rear with 12" rear rotors and a front FSJ Dana 44. What distribution block have people used with a rear disc upgrade. Would stock setup be ok with a 1/4 brake line going to 2 3/16" lines going to each disc at the rear? and 2 3/16" to the front.
Any help would be great.
jarcher401 is offline
post #2 of 8 Old 03-24-2013, 07:34 PM
BlueRubiconrich
JP mag I think ran a issue on that maybe try there.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 8 Old 03-24-2013, 08:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Doesn't need larger rear main line.
No proportioning valve works just as well as one from a disc/disc jeep like a grand.
Be sure your master moves enough fluid and your booster has enough pressure assist for the size calipers you're using.
ratmonkey is offline
post #4 of 8 Old 03-28-2013, 08:21 PM
foggybottombob
Be sure you have a 2# residual valve on the rear line. That is about right for small rear calipers. I have El Dorado rear calipers now on a rear Dana 60 and a 10# residual valve works well with those.
foggybottombob is offline
post #5 of 8 Old 03-28-2013, 08:50 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Residual valves are for drum brakes. Disc brakes don't use them.
post #6 of 8 Old 04-02-2013, 03:55 PM
foggybottombob
Residual valves are definitely needed for at least some disk brakes. I had 300ZX calipers on a rear Dana 44 axle and no residual valve. You had to hit the pedal twice to get good rear braking. Drum brakes use a 10 # residual valve but disk brakes need something less like a 2#. If you have no residual valve one pedal push is not enough to move the pads enough to stop.
post #7 of 8 Old 04-02-2013, 06:07 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
sounds like a band aid for a master that didn't have the volume to do what you needed it to.
post #8 of 8 Old 04-02-2013, 07:49 PM
foggybottombob
That makes sense. But it works.
