Hydrolic steering? - JeepForum.com
post #1 of 5 Old 04-11-2012, 08:10 AM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Hydrolic steering?
Here do I look, and what is needed to go fully hydrolic steering? I have a waggy 44, but would like it to work on a 60 if I ever go down that road.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #2 of 5 Old 04-11-2012, 10:09 PM
scubamc
http://www.pscmotorsports.com/
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 5 Old 04-11-2012, 10:15 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Wondering what I need. Ram, tie rods, pump, steering column. How do these systems work? Is there a kit? Would high steer kit be better for 36s?
post #4 of 5 Old 04-11-2012, 11:26 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Psc.
High volume pump, cooler, high volume reservoir, orbital valve, double ended ram,
plenty of discussion on hydraulic steering in mc and pirate...being topic of the month and all before.
ratmonkey is offline
post #5 of 5 Old 04-12-2012, 05:00 AM
jason m
Nothing but the facts
jason m's Avatar
I have a steering valve from a fork truck thats open center and 4.5 cubic inch displacement, Two rams from tractor supply witch are 2" boar 1 1/8" chrome rod ( I have rear steer so two rams are needed of course ) and then a log splitter valve to control the rearsteer.
For a pump I run a one ton Chevy P-pump, they deliver the most pressure and flow for a off the shelf pump, I also run the stock can to suround the pump with fluid insteed of a stand alone pump with a seperate Res. This way the fluid is allways inclosed with the pump and it cant starve if you flop on your side.
Cooler, I run a large after market cooler used in dirt racing, I don't know the brand name I bought it used at a swap meet.
Line's, I run all -6 with JIC and Pipe fittings, carry alot of extra fittings and one universal line that should cover end to end.
Ive built Hydro systems when I worked for CAT as a welder, so it was easy for me. A kit might be a better choice for someone without the know how, as everything is all ready doped out.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
