Help with wheel and lift advice - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Advanced Jeep Tech > Help with wheel and lift advice
ZONE 4.25" combo lift for TJ available at Rockridge4wNEW!! HMF 50"-52" light bar mounting brackets!! ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 03-27-2014, 01:48 PM   #1
Dflores0625
Can someone help me out with this question...I recently got a 2012 JK with stock Rubicon wheels an tires... 255/75/17...does anyone know if the stock wheels will work with a 3.5" lift kit? Or will I need spacers?
Dflores0625 is offline   Reply With Quote
Unread 03-27-2014, 03:06 PM   #2
jp360cj
1977 CJ7
That's going to depend on what size tis you want to run after the lift.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline   Reply With Quote
Unread 03-27-2014, 03:27 PM   #3
Dflores0625
jp360cj My plans are to get some 35's but for now I was going to run the 32's that's what's on the wheels right now. They are from a Rubicon. Do you think spacers would be necessary with 32's on 17" alloy wheels?
Unread 03-27-2014, 03:40 PM   #4
jp360cj
1977 CJ7
The lift will have no affect on the current wheels& tires. You will only need wheel spacers if you get taller& wider tires that rub.
