Help!-codes everywehre - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Advanced Jeep Tech > Help!-codes everywehre
GEARSHADE Pocket Tops in stock and available at ROCKRIDGE Engo winches available at www.rockridge4wd.com! Free shippFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 07-17-2014, 03:46 PM   #1
redwings8912
I have a 205 Jeep Cherokee Limited with just over 100,000 miles. Abut 2 weeks ago I had the "trans over temp" warning pop up. Got the code read as P0218. Had the Solenoid Assembly fixed and was fine.
Today I had the same "trans over temp" light pop up, shut my car off, and pulled into AutoZone. Came back, started the car but the code was gone. Left to head home but the light came back on so I turned around. Leaving my car run the below codes were read:
P0868: Line Pressure
P0944: Loss of Hydrolic Pressure
P0218: High Temp Operation
C140F:transmission case range position sensor erratic
The trans fluid is fine with levels correct and no sign of it be burnt. There is no noticeable slipping of the transmission when driving.
Anyone have any ideas of what could be wrong? My only thought is the TCM..
redwings8912 is offline   Reply With Quote
