Gauge Replacement 97 TJ - JeepForum.com
post #1 of 6 Old 04-29-2013, 03:54 PM Thread Starter
DaveLotek
My gauges are acting up and I'm thinking about switching to after market ones. I am wondering if a cable driven CJ style mechanical Speedometer would work with the TJ's NV231 transfer case. Can you unscrew the electronic sensor and screw in a speedo cable instead? Any thoughts are appreciated. 97 TJ 2.5, 5 Spd. Manual
DaveLotek is offline
post #2 of 6 Old 04-29-2013, 09:09 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
computer needs the vehicle speed information sent by the electronic speedo.
ratmonkey is offline
post #3 of 6 Old 04-30-2013, 08:12 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I'd leave the t-case end and electronic setup as is. If you want an aftermarket gauges (I went with Autometer), contact the gauge MFG to see if they can handle the CAN BUS feed from the existing setup, or contact DakotaDigital.com to see if they have an adapter module to convert the CAN BUS feed to a proper gauge signal for the chosen gauge.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #4 of 6 Old 04-30-2013, 02:00 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
autometer does have an adapter to use to tap into a chrysler electronic speed signal.
a cable driven speedo would drop right in where the electronic vss is currently at. they were manufactured with the same standards across the industry for decades.
post #5 of 6 Old 04-30-2013, 09:41 PM
sduncan
sduncan's Avatar
Maybe contact these guys....
http://www.speedhut.com/gauges/freedom-gauges/36:5
'98 TJ, 5.7 HEMI,
sduncan is offline
post #6 of 6 Old 05-01-2013, 05:11 AM Thread Starter
DaveLotek
Thanks for the comments. Any more thoughts are appreciated too.
