full width axles on a JK with working ABS/ESP -- who makes them? - JeepForum.com
post #1 of 10 Old 02-08-2012, 06:14 PM Thread Starter
guarnibl
2009 JK Wrangler
Hi guys,
Looking to get some full width Dana 60 axles that will bolt into a JK that are FULL WIDTH. Reason being I want to be able to effectively mount coil overs in the rear outside of the frame when I do an 8" rear stretch.
My concern is this Jeep is still going to need to be driven on a day to day basis. Not every day, but I refuse to sacrifice the ability to drive it daily. As such I am looking for full width axles that I can purchase (don't need full floater) that have ARB air lockers, 5.38's, and work with ABS/ESP.
Thoughts? Otherwise I'm going to be stuck with a good coil spring/shock setup in the rear -- which, while fine -- I prefer coil overs so I can adjust/rebuild them.
Have some G2 D60's about to be ordered but I'm waiting until I get the answer on this. Looks like Currie might make some stuff. What's considered full width (enough to the point where I can mount coil overs on the outside of the frame) ?
2009 Jeep Wrangler Rubicon (6mt) (in progress)
- 42x14.50 MTR's, Custom Cage, FF D60's F/R w/ ARB's and 5.38's, 4 Link Rear, 3 Link Front, 14" RR King 2.5's, 18" RR Fox 2.5's, Fox Air Bumps
- 108" wheel base
guarnibl is offline
post #2 of 10 Old 02-12-2012, 11:22 AM
joe_and_jeep
You need ABS and ESP to drive daily? AAM axles out of a Dodge might work, the Chevy guys use them for SAS in newer trucks because of the ABS.
joe_and_jeep is offline
post #3 of 10 Old 02-12-2012, 11:45 AM
fratis
fratis's Avatar
if you want bolt-in dynatrac, currie, etc are what youll be looking at. might still need to notch the rear frame to outboard your rear shocks. you have to make sure there is room for the tire when flexing not just up and down but when one is up and the other down. this causes the top of the tire to pinch in.
why the axles? thought jk guys were happy with 40s on stock hardware?
-insert meaningless out-of-place political diatribe-
fratis is offline
post #4 of 10 Old 02-16-2012, 11:03 PM Thread Starter
guarnibl
2009 JK Wrangler
The guy that installed my gears totally ****ed my rear axle, so decided rather than buying another D44 just do it once and do it right But yeah, I'm still running a D44 front and it's fine. Just have it trussed, sleeved, gusseted, etc.
And yeah, we will have to notch the frame a bit even with the 69" wide axle (provides us with about 62 1/8th of housing width). Running King 2.5 14" coil overs front and rear, and bypasses through the tub.
Edit: Looks like planman finally borked his axles on 40's. So perhaps the opinion of 40's on 44's will change. I have the cash to buy new axles... lots of people don't. So I was willing to risk it.
- 108" wheel base
guarnibl is offline
post #5 of 10 Old 02-17-2012, 12:49 AM
RockRodHooligan
RockRodHooligan's Avatar
http://www.currieenterprises.com/ces...6.aspx?id=3458 + http://www.truehi9.com/index.html =
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #6 of 10 Old 02-17-2012, 05:03 AM
jason m
Nothing but the facts
jason m's Avatar
Question, with the ABS how does the single get piclked up on the JK's. I ask because alot of the newer FF rears like the 10.5 steerling and the AAM's have a tone ring and I think that's how the trucks pick up the single.
I saw one dana 60U out of a late model Ford van with a tone ring on it to and even a few 70's from time to time with them.
Fronts that might be tricky, unless you find a newer Ford 60 and then I'm not even sure they have the wiring on them.
Hmm, thats a tuff question, my normall responce is just throw a 60/14bolt at it but you can't....................
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #7 of 10 Old 02-18-2012, 06:57 PM
benmar2000
When I had my JK, I thought about getting the axles out of a Power Wagon.. They are full width and the ABS/Speed sensors look to be compatible with the JK.. Keep in mind that a JK has to have ABS/Speed sensors at each wheel or the computer will throw a CEL and maybe even an ABS light..
benmar2000 is offline
post #8 of 10 Old 02-21-2012, 10:38 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
JK uses a tone-ring at the end of each shaft and a sensor through each caliper bracket.
I got the tone-rings from Currie > http://www.currieenterprises.com/ces...6.aspx?id=3440
With a little machining and finesse they could be added to most disc brake axles.
Jim
JLC08JK is offline
post #9 of 10 Old 03-09-2012, 06:07 PM
Bennettj13
Why am I the only one that sees a problem with asking for a bolt on solution in advanced tech? What the ****.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #10 of 10 Old 03-16-2012, 01:34 PM
AKGeo
First thing I noticed.
AKGeo is offline
Full hydro setups Machinist Advanced Jeep Tech 35 02-24-2012 10:19 PM
