Front trackbar relocation after OTK - Page 2 - JeepForum.com
post #16 of 20 Old 01-20-2012, 08:05 PM
pcoplin
pcoplin's Avatar
I would make a straight trackbar since you have to cut that one down. I've done it a couple times and it will work better. Then you can buy/fabricate a proper double shear mount at the frame.
IF you don't want to fabricate an axle mount the JKS piece works well.
pcoplin is offline
post #17 of 20 Old 01-20-2012, 10:15 PM Thread Starter
Hussler
1992 XJ Cherokee
I assume then if I went double shear at the frame that I would want the end in the exact same location, just rotated 90 %%d ?
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #18 of 20 Old 01-20-2012, 10:26 PM
pcoplin
pcoplin's Avatar
It would allow you to move it forward a touch since you would use a non-bent trackbar. You'll want to do this to clear the diff. Just watch the pitman arm clearance. The RE mount may work, but I haven't used it. I built one similar for my wife's XJ for the RE bar.
Here's my TJ though at full bump. Yours won't need to be so tight, this has 2 inches of stretch.
pcoplin is offline
post #19 of 20 Old 01-20-2012, 10:43 PM
Climbit
Originally Posted by foggybottombob View Post
If you have the track bar enter the bracket at an angle (say 3 degrees) that is slack for track bar movement that you don't have otherwise. I can say that changing the track bar 3 degrees was one thing that eliminated my DW.
what slack? unless you are using a bushing, and having it enter the bracket at an angle... but that would be silly...
Climbit is offline
post #20 of 20 Old 01-21-2012, 07:50 AM Thread Starter
Hussler
1992 XJ Cherokee
Based on the picture he posted he did use bushings, which actually brings me to my next question bushings heims or jhonny joints? I imagine that the consenses is using to using heims on both ends?
Hussler is offline
Your axle end swaybar relocation for OTK Hussler Advanced Jeep Tech 17 03-29-2014 09:58 PM
