Front trackbar relocation after OTK - JeepForum.com
post #1 of 20 Old 01-15-2012, 04:26 PM Thread Starter
Hussler
1992 XJ Cherokee
I'd like to see how you guys moved the axle end of the trackbar up. Did you cut off the front mount and weld up a new one? Beef up the steering stabilizer mount and use that? Custom track bars? Modified aftermarket ones? I'm not getting bumpsteer currently but hey, why not make it right!
Personally I was thinking of cutting off the stabilizer bracket and plasmin' myself a new trackbar mount to weld on the surface of the old trackbar mount, so I could keep my old RE trackbar. I believe my trackbar has to move up almost exactly 3 inches, axle side.
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #2 of 20 Old 01-15-2012, 06:49 PM
Climbit
if you can figure out how to keep a stock length (or longer) trackbar and not move the coil buckets back please show me.
Climbit is offline
post #3 of 20 Old 01-16-2012, 08:31 PM Thread Starter
Hussler
1992 XJ Cherokee
Well in order to use the upper stabilizer mount as the new trackbar mount, the trackbar would have to be 3 inches shorter eye to eye than my RE. I wonder what the length of a stock jeep trackbar is eye to eye?
Hussler is offline
post #4 of 20 Old 01-17-2012, 04:36 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Stock trackbar eye to eye looks like 31.25" OC to me Huss.
***Chris***
chris87xj is offline
post #5 of 20 Old 01-17-2012, 06:27 PM
foggybottombob
This is what I did for the OTK axle end track bar bracket. You have to be sure that the track bar enters the bracket perfectly straight. I had a lot of trouble with DW when I went OTK but finally got it ironed out.
foggybottombob is offline
post #6 of 20 Old 01-17-2012, 07:59 PM Thread Starter
Hussler
1992 XJ Cherokee
Thanks chris! My RE one is 32, so I guess using a stock TB is out of the question.
BTW I ended up not using those latches you gave me, want to give me your address so you can have them back?
What do you mean perfectly straight? Like the brackets can't have any misalignment with the TB? Like the brackets have to be perfectly parallel with the trackbar bushing via top view?
Hussler is offline
post #7 of 20 Old 01-19-2012, 10:28 PM Thread Starter
Hussler
1992 XJ Cherokee
Originally Posted by Hussler View Post
What do you mean perfectly straight? Like the brackets can't have any misalignment with the TB? As in, the brackets have to be perfectly parallel with the trackbar bushing via top view?
Bump for answer???
Hussler is offline
post #8 of 20 Old 01-19-2012, 10:33 PM
Climbit
Bump for answer???
no reason why you need the brackets to be perfectly straight unless you are using bushings.
there can be misalignment in the joints if necessary.
what you do need is the TB and DL to be parallel both vertically and laterally.
Climbit is offline
post #9 of 20 Old 01-19-2012, 11:06 PM Thread Starter
Hussler
1992 XJ Cherokee
Didn't know that, thanks!
Hussler is offline
post #10 of 20 Old 01-20-2012, 07:31 AM
Imped
Imped's Avatar
If they weren't, the difference in pivot point locations would = differing arcs = bump steer.
OlllllllO
IndyORV
Imped is offline
post #11 of 20 Old 01-20-2012, 12:12 PM
foggybottombob
If you have the track bar enter the bracket at an angle (say 3 degrees) that is slack for track bar movement that you don't have otherwise. I can say that changing the track bar 3 degrees was one thing that eliminated my DW.
post #12 of 20 Old 01-20-2012, 12:37 PM
GregStephens2
Here is a pic of my set up.
It's a Teraflex hi steer track bar and axle end bracket.
The steering is a customized ORO U turn set up.
It work's great!
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline
post #13 of 20 Old 01-20-2012, 03:16 PM Thread Starter
Hussler
1992 XJ Cherokee
Ok, so through some brainstorming I'm think of cutting off the stabilizer bracket and making a new one on top of the surface of the old track bar bracket. Then, for the trackbar, grind/cut off the bung on the adjustable end (frame end), cutting the trackbar down to size (hack off aprrox 2.5-3") and then re welding the bung. Sound/look like a pretty good idea?
Hussler is offline
post #14 of 20 Old 01-20-2012, 03:30 PM
IEcrawlerTJ01
Is that a Right hand drive stock draglink?
Looks like it
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #15 of 20 Old 01-20-2012, 05:06 PM Thread Starter
Hussler
1992 XJ Cherokee
Yep, works nice. Got a lot of power back out of the steering
Hussler is offline
Your axle end swaybar relocation for OTK Hussler Advanced Jeep Tech 17 03-29-2014 08:58 PM
