frame/pumpkin interference - JeepForum.com
post #1 of 7 Old 03-06-2012, 01:31 PM Thread Starter
barl0w
When adapting a full width Dodge d60 using outboard springs on a CJ , are there any issues with the pumpkin striking the frame under full compression.
barl0w is offline
post #2 of 7 Old 03-06-2012, 05:14 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
How much up travel do you want?
ratmonkey is offline
post #3 of 7 Old 03-06-2012, 06:00 PM
nshefbuch
1982 CJ7
Are you soa or SUA?
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #4 of 7 Old 03-06-2012, 06:43 PM
jason m
Nothing but the facts
jason m's Avatar
Center section should clear without a issue, it would be the steering that might need to be addressed. The drag link could hit the frame under full stuff on the pass side, thats why most YJ guys need to notch the frame.
Now on a CJ it "might" clear but I highly dought it will, probally have the same issue. Another issue is the yoke might hit the down pipe's depending on the motor.
I know my HP 60 has chewd up my crossover pipe real bad, but if it didn't hit the pipe then it would hit the oil pan.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #5 of 7 Old 03-06-2012, 11:48 PM Thread Starter
barl0w
Because of the configuration of the Dodge d60 , I believe it has to be soa.
I can't see how the drag link can hit the frame on the drivers side as the steering box is on the inside of the frame.
This jeep will be daily driver with moderate off-roading primarily in winter so I will not need any excessive travel .
The engine I'm planning to use is a 4bt.
barl0w is offline
post #6 of 7 Old 03-07-2012, 04:23 AM
jason m
jason m's Avatar
Sorry ment to say pass side.
Jason.
jason m is offline
post #7 of 7 Old 03-11-2012, 03:21 PM Thread Starter
barl0w
Has anyone ever adapted an SUA Dodge d60 on a CJ7 front end with a Cummins 4bt engine ?
barl0w is offline
Frame replacement. Building custom frame 95yj-af Advanced Jeep Tech 10 01-23-2012 05:18 PM
Body/frame/unibody mods! Climbit Advanced Jeep Tech 6 01-02-2012 10:30 PM
