Ford 8.8 swap to yj accesories. - JeepForum.com
post #1 of 4 Old 04-07-2012, 01:07 PM Thread Starter
TMSquy
Yj Ford 8.8 swap to yj accesories.
Where do find the emergency brake cable and rear brake hose for 8.8swaps into a yj. any suggested perches? i was gonna plasma cut the old perches and weld them where i need it but any recommendations is greatly appreciated.
TMSquy is offline
post #2 of 4 Old 04-07-2012, 04:22 PM
flea2107
Rubicon Express makes some inexpensive perches. Check out Quadratec online if you don't already shop with them. I swapped out a dana44 from a scout on my 95 and I had new hard brake lines put on it and the emergency brake cables were what was stock on the jeep I believe. Have you lifted your Jeep? When swapping out axles it is best to get a better pinion angle set up then weld on your perches. This will keep your jeep from breaking and losing rear driveshafts. Good luck
flea2107 is offline
post #3 of 4 Old 04-12-2012, 09:50 PM
lutzke21
Ruff stuff 8.8 swap kit is what I went with. There's a few write ups on the e-brake issue too, reusing the jeep stuff.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #4 of 4 Old 04-14-2012, 01:08 AM Thread Starter
TMSquy
Ok, well ive got some time to wait for yet i just got the R and P gears. im doing 4.88's. yeah im about 5inches of lift sua and i was going to tilt around 15degrees. i do already have to adapter flange for the diff yoke. im making a truss on it right now so hopefully ill get it in in about a few weeks. i just want to get all the neccessary parts so i can make this a one day project.
TMSquy is offline
1978 ford hp D60. what front lockout hubs to get? mike_breaker_5 Advanced Jeep Tech 24 04-16-2012 07:26 AM
4.3 tbi swap help. grover_151 Advanced Jeep Tech 8 02-14-2012 05:41 AM
Ford 8.8 Tube Welding rat9 Advanced Jeep Tech 8 02-12-2012 02:42 PM
91 ford 4.0 drivetrain in yj? or body swap? CALUfootball64 Advanced Jeep Tech 32 02-09-2012 07:06 PM
