Ford 8.8 c clip - JeepForum.com
post #1 of 5 Old 12-14-2013, 12:35 PM Thread Starter
boatsandhose
Ford 8.8 c clip
Replacing the wheel studs on my 8.8 w/discs and I couldn't find the right size needlenose so I just turned the gears until the c clip bottoms were facing me and I pushed them down with a flatblade. Now I can't find where the c clip dropped to. It's somewhere in the pumpkin, I can hear it jingle at a certain spot when I rotate the whole axle. I've been fishing around with a telescoping magnet for hours with no luck. Even tried jiggling the whole axle around to jimmy it out but I still cannot locate it. Any advice?
90 YJ locked f/r 37s d30 F8.8
boatsandhose is offline
post #2 of 5 Old 12-15-2013, 07:29 AM
jason m
Nothing but the facts
jason m's Avatar
Are they in the carrier around the spider gears? Or maybe stuck in the oil passage but I don't think the oil passage is big enough for a clip let alone two to fall in there.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #3 of 5 Old 12-16-2013, 08:35 AM Thread Starter
boatsandhose
I suspect they may be in the carrier. I failed to mention I only pulled one shaft and the other c clip is still on the other shaft.
Sent from my Galaxy Nexus
post #4 of 5 Old 12-21-2013, 10:53 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I assume you found it by now (been 5 days). If not, pull the whole axle and ship it to me, I'll get it out for you.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #5 of 5 Old 03-21-2014, 09:50 AM
badv8s10
Couldn't have went far did you pull the other axle and look above the pinion?
badv8s10 is offline
