Ford 8.8 axle tube welding - JeepForum.com
post #1 of 20 Old 02-03-2013, 07:18 AM Thread Starter
Homebrewed2
Yj Ford 8.8 axle tube welding
I am getting ready to swap a ford 8.8 in my YJ and I want to weld the axle tubes to the pumpkin. I have been doing some searching on the internet and get mixed results. I will be using my Miller 211. Some sights say to use high nickle wire other say regular wire is fine. I figured I would get some opinions on here before I try anything. Thanks
Homebrewed2 is offline
post #2 of 20 Old 02-03-2013, 12:33 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Mine was TIG welded with high nickle rod, but its certainly not a requirement. Solid or flux core in your machine works fine as well.
Joe Dillard is offline
post #3 of 20 Old 02-03-2013, 07:13 PM
89YJBuilder
Would you think 6011 or could 7018 be used?
Keep your boogger hook off the bang button!
When all else fails... ham radio is there!
KG6YSF
89YJBuilder is offline
post #4 of 20 Old 02-03-2013, 09:19 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
This is not a recommendation, just saying... I didn't know steel/cast welding was a big deal when I welded mine 7-8 years ago, so I just welded it like it was all steel with my MIG. Alls well since then.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #5 of 20 Old 02-03-2013, 09:53 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
This is what I did. I found a junk rotor and welded scraps of steel to it. Once I was comfortable with welding the two together, I moved to my axle.
I welded one inch at a time on one side, then the other. Waited an hour. Then welded the opposite side of the tube, then the other. I did this until the tubes were fully welded to the pumpkin.
I welded my rear axle a couple years ago in February in weather that was in the teens with my Hobart 140 with FLUX wire.
Mail crawling.
MisfitSeven is offline
post #6 of 20 Old 02-04-2013, 01:00 PM
89YJBuilder
I wouldn't have thought that that machine had enough amps to weld that heavy of material. I would have wanted a bigger machine and I think I will preheat before welding.
My thought.
KG6YSF
post #7 of 20 Old 02-04-2013, 01:23 PM
MisfitSeven
MAiL Crawler.
My thought.
I welded my 8.8, my friends 8.8, and my dana 30 from my TJ before I sold it. So far, so good.
Mail crawling.
post #8 of 20 Old 02-04-2013, 06:11 PM
BlueRubiconrich
I use 7018 when I have welded on shock mounts and spring perches.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #9 of 20 Old 02-05-2013, 01:34 PM
xtremzj
same here, everything ive welded on my jeep is from my Hobart 140
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline
post #10 of 20 Old 02-05-2013, 07:56 PM
89YJBuilder
I've built several things for my Jeep with a Lincoln weld pack 100. The bumpers have taken a pounding and are still good and solid. They are 3/8 and under steel. The axle housing is is cast steel and the tubes are usually high carbon steel if I remember correctly so those being welded together require preheat and post weld controlled cooling in order to do it right. That is what I was taught however if you have done it and it works and holds that's what counts. So did you do any preheating? I want to know so I can do the same. I'm not trying to be a pain or smart a**.
KG6YSF
post #11 of 20 Old 02-05-2013, 08:03 PM
MisfitSeven
MAiL Crawler.
I didn't preheat.
Mail crawling.
post #12 of 20 Old 02-05-2013, 08:07 PM
89YJBuilder
Alright cool that will make things easier. Thanks.
KG6YSF
post #13 of 20 Old 02-06-2013, 04:49 PM
zarnold
Pics, of the process (if possible).
zarnold is offline
post #14 of 20 Old 02-07-2013, 02:07 PM
dhubing
I pre-heated (the cast part) to 400ish degrees and welded with standard Mig. Then post heated.
dhubing is offline
post #15 of 20 Old 02-23-2013, 03:46 AM
Shadownwpa
If you have to use stick and want a weld that doesn't look like hammered sh*t then I'd recommend the 7018. When considering filler metal for strength keep in mind the 70 or 60 at the start of the 7018 or 6010 indicates the tensile strength of that rod.
As far as doing this without preheat... that's up to you but I'd take the time and do it. At a minimum it will burn off some oils that may still be on the metals.. it also helps the weld tie in better, and it reduces distortion, it reduces the heat affected zone surrounding the weld (where it will break first if it gets tempered) by spreading the heat over a larger area so you don't have just a narrow strip of rapidly cooled metal right next to the weld. Make sure you clean the areas where you'll be welding of rust, paint, anything but clean metal.. unless you want to have the welds look like swiss cheese.
Shadownwpa is offline
