Flattening the steering box? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Advanced Jeep Tech > Flattening the steering box?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueYukon Spin Free Kits -Jeep Wrangler Bushwacker Flat Fender Flare Sale at Baselin
Unread 04-21-2014, 11:12 PM   #1
pcoplin
pcoplin's Avatar
Stock the steering box is tilted down in the front. I'm thinking of mounting it parallel with the frame rail, up into the grill a little bit. I'd have to run a dropped pitman arm instead of the flat, but it would give me clearance for my radiator X-member. This is what I'm working with:
Is there any issues I can't forsee running it flat? My thoughts were it would keep the pitman arm side the same height across the travel. I'm using GM high angle rod ends for my drag link.
Thoughts?
98 TJ 5.9 Stretched and big axles
01 F250 Powerstroke 7.3/ZF6
pcoplin is offline   Reply With Quote Quick reply to this message
Unread 04-22-2014, 03:55 AM   #2
jason m
Nothing but the facts
jason m's Avatar
I don't see a problem with running the box flat, it wont hit the box frame as you swapped it over to tube like they normally do.
But what I do see is your approach angle is going to suck, no offence. Why is the Rad. so far away from the motor, I know you need room for the electric fan/fans but it seems like a lot or room in between there.
To me you can come back almost 6-8"s and that will still let you drop the winch in its hole and can make the overall of the front clip close a foot smaller.
Maybe you have other plans for the space, but unless your running 42"+ tires your bumper will be eating everything up front first.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt....
jason m is offline   Reply With Quote Quick reply to this message
Unread 04-22-2014, 09:02 AM   #3
pcoplin
pcoplin's Avatar
What I do see is your idea is going to suck, no offense. I think it'll be fine.
Unread 04-22-2014, 09:16 AM   #4
pcoplin
pcoplin's Avatar
Originally Posted by jason m View Post
I
Jason.
I just have a V8 with a gutted grill. The grill is in the same position as stock, the bottom is tilted out an inch, and the tube bumper is close to the stock bumper. Probably just looks like a lot of room.
