First Gear Swap Waggy D44 & Front OX locker - JeepForum.com
post #1 of 14 Old 09-24-2012, 06:32 AM Thread Starter
HaskiE
HaskiE's Avatar
I'm working on changing the gears in a Waggy D44 front axle, 3.31 to 4.88. standard carrier to OX locker. made setup bearings, got the pinion bearing preload, backlash & carrier bearing preload to spec, and finally got a good pattern.
Pressed on the new bearings and had to completely re-do my pinion bearing preload... and then when I dropped in the carrier there was zero carrier preload! and NO backlash! the Timkin bearings are the same part number; setups are The originals from 1991 (I think) and according to the surface plate at work they're about 0.0045" shorter than the new ones... what would cause this?? I measured the bearings 3 times just to be sure, the old ones are smaller...
ruined shims... going to order more...
Did I press on the new bearings ...too hard? I'm starting to think the shims walked up the taper on the ox locker? Has anyone put interior shims on an ox-locker?
#theneverendingaxe
HaskiE is offline
post #2 of 14 Old 09-24-2012, 02:01 PM Thread Starter
HaskiE
HaskiE's Avatar
anyone?
#theneverendingaxe
HaskiE is offline
post #3 of 14 Old 09-25-2012, 01:15 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
just happens sometimes.
i've had one out of 5 axles do that when the real bearings went in.
ratmonkey is offline
post #4 of 14 Old 09-25-2012, 01:27 PM Thread Starter
HaskiE
HaskiE's Avatar
Weird. Thanks ratmonkey! I was starting to think I really F'd something up. What'd you do to finish the axle? Should I make another set of setup bearings?
#theneverendingaxe
HaskiE is offline
post #5 of 14 Old 09-25-2012, 03:06 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
compared measurements and made an educated guess. had to adjust while using the really real bearings twice. it sucked, but sometimes those are the breaks. a clamshell style puller would have made things easier. went through an extra pack of shims cause i couldn't be careful enough.
post #6 of 14 Old 09-25-2012, 05:49 PM
HARLEYX2
1987 YJ Wrangler
How did th pinion preload change? Doesnt the front pinion use shims and not a crush sleve? If so your pinion preload should not have changed.
HARLEYX2 is offline
post #7 of 14 Old 09-25-2012, 09:31 PM Thread Starter
HaskiE
HaskiE's Avatar
No crush sleeve, yeah, shims on both ends. I made setup races (now I know I only really needed one setup race!) And I'm guessing the bearings are slightly a different size because after I drove in the new races (with what I thought were the right shims behind the big race), and was bringing the pinion to torque I could feel the preload get waaaay too tight... tested to well over 40in lbs; spec is 20-25; so I re-did the preload hoping nothing else changed; but that's when the carrier just slid in with no preload or case spreading... :/
#theneverendingaxe
HaskiE is offline
post #8 of 14 Old 09-27-2012, 09:00 AM
jon87yj
The bearings are different due to variability and being used. Its why you need shims and why there are different preload numbers for new vs used bearings.
jon87yj is offline
post #9 of 14 Old 09-27-2012, 09:58 AM Thread Starter
HaskiE
HaskiE's Avatar
Just ordered another set of bearings & shims (exact same kit) going to shelve my old bearings and make the new ones I have already into setups. hopefully I can get this on try #2!
#theneverendingaxe
HaskiE is offline
post #10 of 14 Old 09-30-2012, 12:37 PM
foggybottombob
Good luck with try #2. It usually takes me 10 to 20 tries to get a dana setup correctly.
foggybottombob is offline
post #11 of 14 Old 10-01-2012, 01:01 PM Thread Starter
HaskiE
HaskiE's Avatar
hahaha I hear that! It took me about a whole afternoon to get the shims right on the pinion first and then the carrier took about the same, and then I did the pinion again... I dont even want to think about how much time I have into this!!!! but, learning takes time. Next I'm honing the bearings out with the dremmel to make the new setup's; when the new bearings finally get here with the new shims hopefully I't be a swap and load, done....
#theneverendingaxe
HaskiE is offline
post #12 of 14 Old 10-17-2012, 06:05 PM Thread Starter
HaskiE
HaskiE's Avatar
Ok so new bearings finally came in, and I'm making my new setup bearings, and maybe I'm over thinking this, but I wanted to get your guys thoughts on this; Last time I swapped out all 4 bearings (cone+race) for setups. I'm thinking it might be smarter; or (possibly the right way?) to start with the final side races & final inner cone? Ie, use as many final parts as I can...? Drawing:
#theneverendingaxe
HaskiE is offline
post #13 of 14 Old 10-17-2012, 08:10 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
on the d44/60 i use the "good" inner pinion cone and outer pinion cup. they don't have anything under them that needs adjusted so there's no reason to go through the effort of set up bearings/races.
i use whatever was matched up on the carrier bearings.
post #14 of 14 Old 10-18-2012, 05:25 AM Thread Starter
HaskiE
HaskiE's Avatar
That's just what I wanted to hear! thanks man!
I made 2x setups last night, hopefully I can make some progress tonight.
#theneverendingaxe
HaskiE is offline
8.8 Swap Gear Pattern Help... raymond3080 Advanced Jeep Tech 6 09-05-2012 01:46 PM
waggy 44 tj swap inner c question curlytj3582 Advanced Jeep Tech 4 09-01-2012 04:52 PM
Waggy d44 balljoints mncdriver Advanced Jeep Tech 18 06-18-2012 01:11 PM
Waggy front high steer Ripper3494 Advanced Jeep Tech 13 02-07-2012 07:36 AM
