Engine Swap, Need some help guys! - JeepForum.com
post #1 of 18 Old 01-09-2013, 08:46 PM Thread Starter
Collin89Sahara
Yj Engine Swap, Need some help guys!
Ok, after my Jeep sitting for months with a tired, broken engine. I have the resources to breathe new life into her!
If I can swing it, I would like to go with a budget AMC 242 stroker and an AX-15.
Can you guys help me come up with a list of things I need to make this swap possible?
Here is what I have so far:
1. Stroked 242
2. AX-15
3. Clutch Plate
4. Flywheel
5. 1991+ computer for my 1989.
6. Water pump
7. Thermostat
8. Radiator
10. Belts
11. Injectors
There are many other parts that I am sure I haven't thought of, can I please have some help on a list of all the "little" stuff I need to make this happen? For example, will I need to match the splines of the transmission to the transfer case. I know that the D35 won't be able to handle this load, I have a Chrke 8.25 and 29 spline/tracloc/3.55's in the garage as my rear end.
Thanks in Advanced,
Collin
Collin89Sahara is offline
post #2 of 18 Old 01-10-2013, 07:44 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
If the old drive train setup is stock and no mods added, I'd just pull the whole motor/trans/tcase, toss it, and swap in a newer version of everything.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 18 Old 01-10-2013, 08:01 AM Thread Starter
Collin89Sahara
I am keeping the transfer case as it is fine.
post #4 of 18 Old 01-12-2013, 08:12 PM
rjbruzan
AX-15 will need a 23 spline T-Case as yours will be a 21 spline and AX-15 is 23 spline.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #5 of 18 Old 01-14-2013, 03:49 PM
JeeperDon
JeeperDon's Avatar
As was said just above, the t-case isn't fine. I can tell you that it's a PITA to swap the front input shaft in an NP231. You would be better off swapping that too. You asked for advice, thats what I advise.
Web Admin for
post #6 of 18 Old 02-18-2013, 12:08 PM Thread Starter
Collin89Sahara
Thanks for all the input guys! Since money is tight and I am on a $2k budget, I won't be touching the trans or Tcase anymore. I do have a question though, would a 4.0l cam fit in a 4.2l?
post #7 of 18 Old 02-19-2013, 03:33 PM
SgtJensen
From what I've read, and what I plan on doing, it's better off the other way around - swapping the internals from the 4.2L (258) into the 4.0L (242) and stroking the 4.0L to a 4.6-4.7L.
Just a thought, and worth looking into.
Staff Sergeant of Marines - January 2003 - Present
SgtJensen is offline
post #8 of 18 Old 02-19-2013, 04:02 PM Thread Starter
Collin89Sahara
Looked into it. Going less on the engine and more on the trans might be better because the BA10 has 100k+ on it. Think it will hold up to 200-230hp?
post #9 of 18 Old 02-19-2013, 04:08 PM
SgtJensen
I'd be surprised if the BA10 held up to a mouse fart to be honest. I'd look into swapping an AX15 in and mating it to the stroked 4.0L.
post #10 of 18 Old 02-19-2013, 04:28 PM Thread Starter
Collin89Sahara
If I can't find a 4.0 for dirt cheap, the 4.2 will get overbored .040, a 4.0 head, and a weber. Quick question, will a 4.0 cam fit in the 4.2?
post #11 of 18 Old 02-19-2013, 05:19 PM
SgtJensen
Not sure about the cam, but I'm pretty sure the cranks are swappable, IIRC.
post #12 of 18 Old 02-19-2013, 09:21 PM Thread Starter
Collin89Sahara
I know the cranks are, no questions. Just looking for the cam. I am 360+ miles away from home and I don't have my factory service manual to give me all the specs I need
post #13 of 18 Old 02-20-2013, 07:45 AM
-jb-
On a 2k budget a better option would be a 5.2 or 5.9 dodge motor, new motor mounts, possibly center dump headers, a little wiring on your time, mated to an ax-15 with a dodge 3.9 bell housing. If you set the motor right, you can keep your driveshafts the same length. Also a new radiator. Thats about it for big items on this swap.
Thats if you don't want to stroke your motor. I had the parts to stroke a 4.0 to a 4.6 but ended up selling everything just because I wanted a V8 more.
Yellow Jeep Member #42
01 TJ Sport
00 TJ Sport
-jb- is offline
post #14 of 18 Old 02-20-2013, 07:52 AM Thread Starter
Collin89Sahara
Yeah, I'm not looking for a V8 swap bud.
post #15 of 18 Old 02-20-2013, 07:58 AM
-jb-
Not a problem bud, was giving you another option for your price range.
01 TJ Sport
00 TJ Sport
-jb- is offline
