EGR questions with 5.2 Dodge swap - JeepForum.com
post #1 of 6 Old 01-23-2012, 08:43 PM Thread Starter
czjeeper
Yj EGR questions with 5.2 Dodge swap
Does anybody have any idea how much the EGR on the 1992 Dodge 5.2 affects emissions? I know it's there to reduce nox in the combustion chamber by lower the temp.
I have been told by several people that they leave the connector plugged into the computer, but no EGR on the exhaust and it works fine.
If I was to go to center dump shorty headers, I wouldn't be able to keep the EGR.
My rig has to pass emissions, so will I be able to pass the sniff test? No visual here.
The only reason I'm considering headers is I'm using a ZJ passenger exhaust manifold with the EGR, and a 1970's era 318 drivers side center dump manifold.
I get kind of a lumpy idle because of the difference, but no codes and it drives great with lots of power.
I can't use the ZJ drivers side because I'm using the AX15 and it dumps right on top of the starter. The Dodge truck manifold pushed the engine too far forward for my taste, and obviously the engine mounts are welded on now.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 6 Old 01-24-2012, 02:46 PM
pcoplin
pcoplin's Avatar
You may get a code once in awhile (probably won't with OBD1), and I doubt you'll notice a difference in running or exhaust emissions if you have a good cat.
pcoplin is offline
post #3 of 6 Old 01-25-2012, 09:36 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
You get a bad idle, and probably lower power than you should, because of that la style manifold.
Yeah, it will bolt to magnum heads, but the exhaust ports are all wrong and are robbing power
As for the egr, they weren't needed when the obdii systems rolled out, but obdi doesn't control things as well and you may not pass the sniffer.
ratmonkey is offline
post #4 of 6 Old 01-28-2012, 10:01 PM
SunDevilJeeper
This is something I was wondering about as well. I pulled a 5.2 out of a 97 ZJ (using an NV3500 for my tranny) and was wondering about a few things, this was one of them.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #5 of 6 Old 01-29-2012, 09:28 AM Thread Starter
czjeeper
One of the techs I work with is emissions certified for WA state and he told me that they don't check for Nox but, Oregon does, so it would fail down there.
So, I would be good to go for that.
The issues of pinging may be a problem. The EGR introduces exhaust gases to cool the combustion chamber temps. When the temp gets too high (1400 F I believe) high levels of Nox are created.
US Army combat vet
czjeeper is offline
post #6 of 6 Old 01-30-2012, 01:56 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
The 5.2 didnt really need the egr.
Most often pinging is caused by a blown plenum pan gasket.
SBC to a YJ have wiring questions forhiremarine Advanced Jeep Tech 9 02-13-2012 05:30 PM
91 ford 4.0 drivetrain in yj? or body swap? CALUfootball64 Advanced Jeep Tech 32 02-09-2012 07:06 PM
different headers on v8 swap Ripper3494 Advanced Jeep Tech 11 01-12-2012 08:03 PM
