Dodge Dana 60 Hub Removal - JeepForum.com
post #1 of 10 Old 11-26-2012, 08:15 PM Thread Starter
Jeepin72
I have 79 Dodge Dana 60 full floater. I need to remove the hub. I do not want to do the "chisel" method. What size and where do I get the tool to remove the nut on the spindle? I went to NAPA and got blank stares. They had tools for Fords, but no Dodge's.
It is a six sided nut measuring 2.55 inches across. It has rounded sides between each of the six faces.
Jeepin72 is offline
post #2 of 10 Old 11-26-2012, 09:41 PM
jason m
Nothing but the facts
jason m's Avatar
Front dana 60 use's the same size spindle nuts as do 14 bolts.
I use a blunt head chisel and have taken hundreds of axles apart like that but try a truck center they have them or snap on.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #3 of 10 Old 11-27-2012, 05:50 AM
NEastUnlmtd
NEastUnlmtd is offline
post #4 of 10 Old 11-27-2012, 06:39 AM Thread Starter
Jeepin72
Originally Posted by NEastUnlmtd View Post
Yeah, tried that. Having been sold the wrong one once already, I was hoping for some more insight.
Jeepin72 is offline
post #5 of 10 Old 11-27-2012, 07:03 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Pretty sure its a 2 9/16" hub socket.
Got mine from napa.
Chisel is great for removal though. I do follow the torque spec for install though.
ratmonkey is offline
post #6 of 10 Old 11-27-2012, 08:34 AM Thread Starter
Jeepin72
Thanks
Jeepin72 is offline
post #7 of 10 Old 11-27-2012, 08:54 PM Thread Starter
Jeepin72
2 and 9/16 it is. What a difference a NAPA can make. The store that was closest to the shop where we are doing my build is filled some brain dead goons. The shop near my house, a whole different story.
Jeepin72 is offline
post #8 of 10 Old 12-15-2012, 02:27 PM
sjsst41
1978 CJ7
Tech Tip - I've done this:
http://www.globalsoftware-inc.com/co.../hubsocket.htm
And I've also made a socket using an exhaust tube - the trick there is to size the ID of the tube correctly is to measure the length of one side of the nut, multiply by 6 and the ID is equal to that number divided by 3.1415. You have to start to form the 6 sides for the nut on the tube, then use a BFH to "tap" it on to form it properly.
I'll then weld a piece of steel on the backside, and a nut onto that for use of a torque wrench. It like sound like a lot of work, but it's quick to make.
sjsst41 is offline
post #9 of 10 Old 12-15-2012, 03:45 PM
ltrail
1984 XJ Cherokee
That's an awesome idea welding between the points on a piece of scrap pipe
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #10 of 10 Old 12-15-2012, 05:06 PM Thread Starter
Jeepin72
That is genious
Jeepin72 is offline
