Different Width Axle Advice (Poll) - JeepForum.com
View Poll Results: To lengthen or not to lengthen and how to go about it?
Leave it be with rear axle 6" wider 2 8.33%
Add 2" adapters to the front making the difference only 2" total 7 29.17%
Add 3" adapters to the front making the axles the same length 2 8.33%
You have no business owning this Cherokee. Drive it off of a cliff immediately! 9 37.50%
Other - please specify 4 16.67%
Voters: 24. You may not vote on this poll
post #1 of 87 Old 03-03-2013, 09:32 AM Thread Starter
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
Ok, long story short... I have a Waggy D44 and a Ford 9" that I just put under my '92 Cherokee. I'm a ******* and didn't realize that the 9" was THAT much wider than the D44. I just eyeballed them and thought they looked close enough. After measuring the 9" is 6" wider than the D44. I am NOT buying new axles, so help me decide what route to go here. This is primarily just a trail rig, but will see light road use to/from the trails.
Options....
1 - Just roll with the width difference, which also has me running different bolt patterns, but I found wheels that match. Waggy is 6x5.5 and Ford is 5x5.5. I would just pick up a 2 piece adapter for the spare, so I only have to carry one spare along....
Pick up wheel adapters from this guy http://www.motorsport-tech.com/ Who I've been talking to and said he can make me 2 or 3" adapters that will be hub and wheel centric that will work well and put no extra wear and tear on any other parts.
2 - So, 2" adapters
3 - or 3" adapters
Again... I do not have the money to go in a different direction at this point and I'm too anxious to get the Jeep back on the trails after being down for so long. So, one of these IS happening.
*edit*
after voting please add a comment explaining your reasoning. Thanks
koolaid5 is offline
post #2 of 87 Old 03-03-2013, 09:39 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Using spacers on your steering axle is really rough on the wheel bearings. You could end up rebuilding the d44 a couple times in the next 10 years.
D3<!L!>3D
S8NNG8 is offline
post #3 of 87 Old 03-03-2013, 09:47 AM
biffgnar
biffgnar's Avatar
How is it any different than running wheels with lower backspacing?
biffgnar is offline
post #4 of 87 Old 03-03-2013, 10:02 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Depending on how much that would cost me to replace myself I'm not really worried about it. Keep in mind the XJ will see very little use. As much as I would like to take it out every weekend Between my soccer, son's soccer, daughter's gymnastics and dance....other family fun. I have very little "me" time. I'm guessing I'll get away to wheel it maybe 5-6 times a year?
koolaid5 is offline
post #5 of 87 Old 03-03-2013, 10:03 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
It's no different, crazy backspacing will cause you the same problem. Pick up one of your tires and see how long you can hold it, now rest up and do it again, but this time hold the tire 2-3" from your body It can be done, just make sure you repeatedly check to make sure the spacers stay tight.
D3<!L!>3D
S8NNG8 is offline
post #6 of 87 Old 03-03-2013, 10:07 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Stop and go street driving, and pot holes will be the enemy These are just issues to be aware of, it doesn't make the mods undo-able.
D3<!L!>3D
S8NNG8 is offline
post #7 of 87 Old 03-03-2013, 10:09 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
That's not a problem at all. Like I said it will see little use to begin with. I have no issues checking the torque of ALL the lug nuts/bolts before each trip out. From what I've read that is the biggest issue and what causes damage from running adapters/spacers. Not checking the torque, having them loosen up, and a wheel falling off or lugs snapping off.
koolaid5 is offline
post #8 of 87 Old 03-03-2013, 10:11 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Jeeps are infinitely modifiable, anything goes, make it yours and love it. The drivetrain mods are each going to do something to way it rides and drives, but that's just what makes it all the more unique
D3<!L!>3D
S8NNG8 is offline
post #9 of 87 Old 03-03-2013, 10:14 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
I drove it around the neighborhood (still need to get my rear shock mounts welded, so it was acting a bit funky) and the steering didn't feel bad at all. I felt a little "push" through the corners because of the wider rear, but nothing I couldn't live with....barely noticeable. So, if that is the major issue with running a wider rear axle I don't know that I'm really worried about it. I could pick up the 2" adapters. They aren't quit as extreme as the 3" flavor, will give me the same bolt pattern all around, and should help a little with that "pushing" through the corners.
That's what I'm leaning to at this point in time anyway.
koolaid5 is offline
post #10 of 87 Old 03-03-2013, 10:15 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
S8NNG8 - thanks for the quick feedback and advice on this. Vote in the poll already
koolaid5 is offline
post #11 of 87 Old 03-03-2013, 10:16 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Here's a choice I made that others seem to frown upon. Do you see how much my rearend stands up?
You'd never guess it has 200+lbs of this in the back
D3<!L!>3D
S8NNG8 is offline
post #12 of 87 Old 03-03-2013, 10:19 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
What is that in the back? Post more pics
koolaid5 is offline
post #13 of 87 Old 03-03-2013, 10:20 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
You can also have the spacers welded on, but I'd think not cuz you'd be welding them to the rotor(which is slightly disposable
D3<!L!>3D
S8NNG8 is offline
post #14 of 87 Old 03-03-2013, 10:21 AM
nshefbuch
1982 CJ7
How would you change a stud then?
Plus spacers are usually aluminum and rotor is cast. Not sure you can weld those together.
I don"t like spacers at anything over 1.5" let alone 3" seems to much stress on studs(which would be aluminum most the time as well).
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #15 of 87 Old 03-03-2013, 10:22 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Yeah, don't worry about discussing this. I'm not going that route.
koolaid5 is offline
