Cutting and turning knuckles on a scout 44 - JeepForum.com
post #1 of 7 Old 01-16-2013, 03:28 PM Thread Starter
HighFive
1981 CJ5
What is the best way to cut and turn the knuckles on a scout II dana 44. Should I grind the welds out or torch the weld out. If we torch it out will the heat weaken the knuckle? What's your opinions. Thanks
[/color]
Let's go Flyer's!!!!!!
HighFive is offline
post #2 of 7 Old 01-16-2013, 08:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
grind, torch can be hard to control in that kind of situation.
ratmonkey is offline
post #3 of 7 Old 01-17-2013, 03:28 PM
foggybottombob
Also, I have never been able to turn an inner knuckle once the weld was ground off. I have to knock the Cs off and then put them back on at the desired angle.
foggybottombob is offline
post #4 of 7 Old 01-17-2013, 04:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
they're supposed to be a slight press fit. heating them before slapping them back on gives you a little time to work them.
post #5 of 7 Old 01-24-2013, 06:12 PM
BlueRubiconrich
If you wanna make it CJ width cut 3 5/8 off and turn them 6+
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #6 of 7 Old 01-28-2013, 07:10 PM
foggybottombob
That would be OK for no lift or a small lift where you use the stock style front drive shaft.
post #7 of 7 Old 01-28-2013, 07:44 PM
BlueRubiconrich
I've got a 4" lift in my CJ7 with the Scout dana 44 front works great.
