Custom say bar for tj with dbl tri 4 link rear - Page 2 - JeepForum.com
post #16 of 17 Old 03-27-2012, 12:16 AM
aw12345
Originally Posted by ssyj94 View Post
Aw1234 Yeah I dont doubt you do use all the shock travel.... Wish I had such great places to use mine.
What I saw in your first picture is a dual rate stop about 2" below the adjuster. Which would mean you'd be running on the combined rate until maybe the last 1" of uptravel. If the slider even hit the rate stop being that high. I know on my fox shocks it'd never reach didnt think kings were much different. I had my stops high like that in the rear when I first installed them and it was real loose and leaned bad since it was super soft. Adjusted them down and it controls the lean some and rides better at speed. Its kind of a bandaid till a swaybar is added but helps. If you adjusted them after that picture its a mute point just goin by what I saw.
King sells them with the dual rate stop way high and recommends that you leave it alone. I have lowered them some since, doesn't seem to make much difference. Anti rock helped it a lot does very well on winding mountain roads and corners faster than my coil sprung TJ on 35's
aw12345 is offline
post #17 of 17 Old 03-28-2012, 04:48 PM Thread Starter
duggan98tj
Well my jeep has even driven and it doesn't look like I need on at all for now it's was intentionally turn hard at lower speed and high speed to see if I need a sway bar but for now it's not and issue but I will get one at some point
duggan98tj is offline
Need some 4 link help RUoffroader Advanced Jeep Tech 42 08-07-2012 12:06 PM
TJ 4 link suspension in a Samurai?? Lud04X Advanced Jeep Tech 4 03-27-2012 08:56 PM
Frame replacement. Building custom frame 95yj-af Advanced Jeep Tech 10 01-23-2012 05:18 PM
Y-link front suspension Scooter402 Advanced Jeep Tech 67 01-03-2012 07:43 PM
3 & 4 Link Calculators jkl Advanced Jeep Tech 26 12-18-2011 05:44 PM
