Custom say bar for tj with dbl tri 4 link rear - JeepForum.com
post #1 of 17 Old 03-23-2012, 09:49 AM Thread Starter
duggan98tj
Question Custom say bar for tj with dbl tri 4 link rear
So I have a 98 tj with three link front and double tri 4 link rear and fox 2.0 remote res c/o's hp60 front and 14 bolt rear my question is can I use a stock one Ton sway bar for the rear and make my own quick disconnects also using poly mounts for the sway bar? The sway bar will be mounted between the frame and body
duggan98tj is offline
post #2 of 17 Old 03-23-2012, 10:15 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
all that and you want to run sway bar disconnects?
get a pair of anti-rocks.
ratmonkey is offline
post #3 of 17 Old 03-23-2012, 10:28 AM
Imped
Imped's Avatar
You're really limiting yourself by running with disconnected sway bars. Go Currie AR's on both ends and don't worry about it ever again.
OlllllllO
IndyORV
Imped is offline
post #4 of 17 Old 03-23-2012, 11:38 AM
Jankoid
Seriously dude, antirocks. You obviously have the money for them.
Jankoid is offline
post #5 of 17 Old 03-24-2012, 12:11 AM
wushaw
Rockin jeep
wushaw's Avatar
X4 for the anti rock.
wushaw is offline
post #6 of 17 Old 03-24-2012, 07:27 AM
ioman2
unless this is to run on the street i would say you shouldn't need them. if you need them for the trail then you designed your suspension wrong.
00 tj one ton on 42's yadda yadda yadda
82 Cherokee
83 Wagoner (rusted out part donor)
95 xj dd
ioman2 is offline
post #7 of 17 Old 03-24-2012, 09:00 AM
Imped
Imped's Avatar
What are you talking about?
He runs links and coils, not leaf springs.
OlllllllO
IndyORV
Imped is offline
post #8 of 17 Old 03-24-2012, 09:59 AM
lumpster
lumpster's Avatar
I don't need to say this, but run antirocks front and rear. There is no cobbled up one ton swaybar that is going to fit or perform like an antirock.
lumpster is offline
post #9 of 17 Old 03-24-2012, 10:51 AM
aw12345
If all else fails just get the universal antirock kit for the rear that has the right length torsion bar. The stock TJ rear kit is not what you want. Depending on what you all did in the front a front antirock might not be do able. Still just a rear antirock makes a coilovered TJ a lot more drivable. Mine leans a bit in turns but it will out corner my other TJ on 35's
Put the link in the second hole and you are good to go
aw12345 is offline
post #10 of 17 Old 03-24-2012, 02:33 PM Thread Starter
duggan98tj
Ha thanks man I was just asking bc this is the custom section I'm a machinist in te marine corps I was thinking of making a anti rock but just thought that idea was a cool cheap way to run a sway bar and yes I need it to run on the street this is my dd my build thread is project inch worm
post #11 of 17 Old 03-24-2012, 08:02 PM
aw12345
Have you driven it on the road yet? Antirock in the rear atleast is the ticket.
Otherwise the thing will lean bad in a turn and coming out of it
aw12345 is offline
post #12 of 17 Old 03-26-2012, 09:53 AM
ssyj94
I've been DDing my linked up yj for awhile without any swaybars and it really isnt that bad aslong as you adjust the dual rate stop on the coilovers. I've got the stop set about 1.5" above the slider at ride height so it'll lean some then hit the stop and kick into the heavier lower coil. It's actually just as stable as when it had leaf springs.
With this said I'll end up needing an antirock once I start messing with the valving in my shocks. The bar will end up in the same spot as aw12345.
@aw12345 from the picture doesnt look like you'll ever get into the secondary spring
My build:
ssyj94 is offline
post #13 of 17 Old 03-26-2012, 05:55 PM
aw12345
Beg to differ lol
I use every bit of travel on all 4 of those coilovers on a very frequent basis
aw12345 is offline
post #14 of 17 Old 03-26-2012, 07:32 PM
1 ton yj
1 ton yj's Avatar
A sway bar is an important part of any suspension system, on or off road.
1 ton yj is offline
post #15 of 17 Old 03-27-2012, 12:05 AM
ssyj94
Aw1234 Yeah I dont doubt you do use all the shock travel.... Wish I had such great places to use mine.
What I saw in your first picture is a dual rate stop about 2" below the adjuster. Which would mean you'd be running on the combined rate until maybe the last 1" of uptravel. If the slider even hit the rate stop being that high. I know on my fox shocks it'd never reach didnt think kings were much different. I had my stops high like that in the rear when I first installed them and it was real loose and leaned bad since it was super soft. Adjusted them down and it controls the lean some and rides better at speed. Its kind of a bandaid till a swaybar is added but helps. If you adjusted them after that picture its a mute point just goin by what I saw.
My build:
ssyj94 is offline
Need some 4 link help RUoffroader Advanced Jeep Tech 42 08-07-2012 12:06 PM
TJ 4 link suspension in a Samurai?? Lud04X Advanced Jeep Tech 4 03-27-2012 08:56 PM
Frame replacement. Building custom frame 95yj-af Advanced Jeep Tech 10 01-23-2012 05:18 PM
Y-link front suspension Scooter402 Advanced Jeep Tech 67 01-03-2012 07:43 PM
3 & 4 Link Calculators jkl Advanced Jeep Tech 26 12-18-2011 05:44 PM
