Custom CJ7 Front 3 Link Panhard bar problem - JeepForum.com
post #1 of 10 Old 07-07-2013, 03:38 PM Thread Starter
konman2k4
1979 CJ7
Cj Custom CJ7 Front 3 Link Panhard bar problem
Installing a custom 3 link from barnes4wd.com. Got everything in but the panhard bar is going to be a problem. The axle bracket will be way to close to the bottom of the frame. I can fix the problem if I put two 45 degree bends in the panhard bar.
See the attached picture. Will I have problems?
Uploaded with ImageShack.us
konman2k4 is offline
post #2 of 10 Old 07-07-2013, 04:04 PM
jason m
Nothing but the facts
jason m's Avatar
What size tube will get the bends? If its .120 wall 1.5" tube then yes it will bend under a hard side load or a impact.
Can you build a tower off the axle to raise the mount up off the axle tube. This way you can use a straight chunk of tube and now just chunk of .120 wall 1.5" tube can be used without the fear of bending.
Or over build and use some .250 wall 1.5" with miter cuts and re-welded joints.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #3 of 10 Old 07-07-2013, 04:05 PM
rchase559
Assuming your drawing is actually correct and drawn to scale, you will get a warm welcome to bump steer city.
rchase559 is offline
post #4 of 10 Old 07-07-2013, 06:51 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
He's a link to one we're working on right now. Perhaps looking at it will help you see how we are doing it and maybe you can adapt our approach.
http://www.jeepforum.com/forum/f9/sa...4/index79.html
Joe Dillard is online now
post #5 of 10 Old 07-08-2013, 07:59 PM Thread Starter
konman2k4
1979 CJ7
The Panhard bar in the drawing will actually be in front of the axle.
It was my understanding that if the overall length from left to right, no measuring the drop, was the same as the drag link and the angles were very similar it would eliminate bump steer...
post #6 of 10 Old 07-08-2013, 09:06 PM
rchase559
The track bar and the drag link need to be observed from only their mounting points when comparing them. They can be bent into a pretzel in between the ends and it won't change how they behave (well ignoring the fact that they will want to bend more easily of course).
Imagine the track bar isn't bent and compare that to the drag link. The two angles are very different at that point.
Ideally you want the track bar and the drag link to be parallel, the same length, and in the same plane (one is directly behind the other when viewed head on)
post #7 of 10 Old 07-08-2013, 09:36 PM Thread Starter
konman2k4
1979 CJ7
Thanks for the info.. I'll look tomorrow and see if I can make it fit
post #8 of 10 Old 07-08-2013, 09:41 PM
rchase559
Maybe try to find some builds on here or pirate that use a passenger side drop axle in a TJ and see where they routed the track bar.
That may help out a bit as well.
post #9 of 10 Old 07-12-2013, 09:38 AM
Imped
Imped's Avatar
Mounting point to mounting point of both bars need to be parallel....not sure why you would think anything else other than that would result in good steering?
Mount the axle end of the panhard bar to the inner C.
OlllllllO
IndyORV
Imped is online now
post #10 of 10 Old 07-13-2013, 07:54 AM Thread Starter
konman2k4
1979 CJ7
Just bought a full hydraulic steering setup.... Don't have to worry about that drag link anymore
