crank to cam correlation - JeepForum.com
post #1 of 2 Old 11-27-2013, 12:43 AM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
4.6 stroker runs like a champ when warm, but when cold getting some lean misfire. real issue is at start up. takes at least three tries to get to idle and not die. once computer comes out of the loop runs great.
obd 1
have tried most of the tricks to get the two to agree with each other. code says cam to crank correlation.
anyone ever deal with this?
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #2 of 2 Old 11-30-2013, 12:54 PM
uberxj92
1992 XJ Cherokee
Having same issues too on my 4.8 build in a 92 xj. I'm gonna break down and order a scanner. The self test keeps saying map sensor. Swapped three times. I gave a great mechanic I'll look into the cam to crank.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
