Coil spring rates, what to look for? - Page 2 - JeepForum.com
post #16 of 22 Old 12-27-2011, 06:56 PM
2doorxj
2doorxj's Avatar
Originally Posted by Hussler View Post
BDS says they mount the same, and suggested them originally when I asked for a softer rate. I will order them soon
They look different, theres no top tightly wound coil like on the XJs, or at least thats what this pic shows.
2012 Cherokee of the Year
2doorxj is offline
post #17 of 22 Old 12-27-2011, 07:37 PM Thread Starter
Hussler
1992 XJ Cherokee
Hmm, a couple threads with success. No mention of "fit" factor, but thanks for bringing it up just in case
http://www.naxja.org/forum/showthread.php?p=243701445
http://www.virtualjeepclub.com/showt...front-of-an-XJ
http://www.jk-forum.com/showthread.p...ap-easy-or-not
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #18 of 22 Old 01-12-2012, 07:06 PM Thread Starter
Hussler
1992 XJ Cherokee
Alright I'm ready to order some springs, and I still really want the jk ones because of their spring rate.
On the BDS site it says they have the same ID
http://bds-suspension.com/product-display?all
The JK springs do have a decrease in diameter at the top
http://www.ebay.com/itm/Jeep-Wrangle...item43ac19137c
XJ springs
http://www.ebay.com/itm/PAIR-ORIGINA...item35b8689594
If they were a little too wide at the top, couldnt I just weld some circular plate to the top bucket to increase the diameter?
Hussler is offline
post #19 of 22 Old 01-12-2012, 07:13 PM
jsawduste
2006 YJ Wrangler
The JK springs look like they would be a progressive rate. Softer intail travel then firm up.
jsawduste is offline
post #20 of 22 Old 01-12-2012, 07:36 PM Thread Starter
Hussler
1992 XJ Cherokee
Yes the rears look that way but not the fronts? Also looks like stock vs. stock the jk and xj springs have the same number of turns on their springs, so only height and coil thickness would be the determining spring rate factors?
Hussler is offline
post #21 of 22 Old 01-12-2012, 07:56 PM
ftgiles
Spring rates are determined by the diameter of the coil, the wire gauge and the number of active coils. Height has nothing to do with rates.
Progressive springs have less active coils as the spring compresses because as the closer windings touch, they become dead. More active coils, softer spring rate - less active coils, firmer spring rate.
ftgiles is online now
post #22 of 22 Old 01-13-2012, 01:25 PM
edpmedic
http://www.efunda.com/DesignStandard...p_designer.cfm
http://www.pontiacracing.net/js_coil_spring_rate.htm
Hi i'm usually just in the ZJ forum but figured it's time to look around. You guys here are into the advanced stuff and I have not done much Mechanical Engineering since the slide ruler days. Anyway here are 2 sites that will allow you to figure out what your looking for. The thing is once you figure your rates out do they make what you want.
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline
Sua leaf spring info for a tj Nates93yj Advanced Jeep Tech 37 01-30-2013 06:42 PM
