Charcoal cannister - JeepForum.com
post #1 of 6 Old 10-21-2012, 12:26 PM Thread Starter
vortec85cj
Charcoal cannister
My cj7 had the can removed by the po. The engine is a 5.3 and the fumes are bad. Any recommendations for a small compact canister?
vortec85cj is offline
post #2 of 6 Old 10-22-2012, 03:12 PM
Jack15T
Junior Member
1980 CJ7
Try this. You might have to mod it a little depending on how many ports you are needing.
http://www.rockauto.com/catalog/more...754&cc=1182057
Jack15T is offline
post #3 of 6 Old 10-22-2012, 07:28 PM Thread Starter
vortec85cj
My tank has 2 vent holes. Where would the other 2 go?
post #4 of 6 Old 10-23-2012, 04:40 AM
Jack15T
Junior Member
1980 CJ7
I am not sure what your emissions schematic looks like but your canister ports may be labeled right on the can. Just connect those two up to the ports on the new can and cap the remaining two off. That is if somebody hasn't been messing around with your configuration and the vacuum lines are in the correct locations. You might want to take a look at a repair manual for your Jeep and find out what your vacuum lines going to the can are. I am surprised you have only two lines going to your canister. Mine has four.
Jack15T is offline
post #5 of 6 Old 10-23-2012, 07:08 AM Thread Starter
vortec85cj
Sorry for the confusion. My jeep has been stripped of all hoses and lines going to and from my non existent canister . My tank has 2 vents on the drivers side.
post #6 of 6 Old 10-23-2012, 09:59 AM
Jack15T
Junior Member
1980 CJ7
I don't have my manuals with me. I am on the road till this weekend. If those two lines are the same as mine then one is a fuel vent line that goes from the tank to the canister to cover expansion and the other is a return line from your carb or fuel injection. I am not sure which you have. If they are uncapped then you will get a pretty strong fuel oder.
Jack15T is offline
