Cam selection advice - JeepForum.com
post #1 of 8 Old 11-08-2012, 09:05 AM Thread Starter
AughtThree
Question Cam selection advice
OK, I'm rebuilding a SBC 350 to put into my Jeep Wrangler. Looks like I'm going to have to replace the old cam due to wear and tear, and I need advice on how to select the right cam for my application. I'm building a rock crawler, so I'm looking for my power curve to be in the idle - 5000 rpm range. Here's the specs that I know about my rebuild:
SBC 350 bored .040 over
Stock stroke
Decked .020
Vortec heads (64cc chamber, casting #12558062)
GMPP Vortec low-rise intake (GMPP #12496820)
I know that selecting a cam is complicated, so I'm hoping for a little guidance. Can anyone give me an idea of duration/angle/lift I should be looking for?
Thanks!
AughtThree is offline
post #2 of 8 Old 11-08-2012, 11:13 AM
55willystruck
You may be better off calling one of the cam builders and speaking with them directly to find the best application for your needs. While it's a totally different setup, I had excellent dealings with Chris Ryan at Comp Cams. He spent literally hours on the phone over several calls and several emails as well helping out with many different issues and thoughts for my rebuild. I ended up with a custom grind and have been very happy with everything from Comp. Here's his contact info:
Thanks,
Chris Ryan
COMP performance group
Technical Department
3406 Democrat Rd.
Memphis,TN 38118
Phone: (901)795-2400 ext 581
Fax: (901)366-1807
cryan@compcams.com
www.compperformancegroup.com
In the past, I had a handful of 350 chev's and ran several different cams in those with various other parts. Too long ago to recall what all I'd done with each but I do remember never being "happy" with any of the cams at that time, at least that I tried. With my calls and emails to Comp, the customer service blew me away then when it came to install and break in, I'm shocked even more so that the first cam with custom grind worked and did exactly what I'd wanted in this engine for this rig. I've recommended him many times now because of this and I think it would be beneficial for you to contact him as well. If nothing else, at least to point you in the right direction.
Best of Luck,
Mike
55willystruck is offline
post #3 of 8 Old 11-08-2012, 12:10 PM
ltrail
1984 XJ Cherokee
I was building on the cheap and effective route. Mine came with ugly flat tappet origionally but block was drilled for roller tray. I used an LT1 cam and swappe to full roller. Less drag, slightly larger cam, still keeping in a reasonable range with the power. Fine tuning a cam is the way to go this is true. For budget build i opted for low mileage take out.
Just try to keep your power in the range you will be operating in and you will be happy.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #4 of 8 Old 11-08-2012, 02:43 PM
pete1991YJ
The old favorite was Comp Cams 268 with a few degrees of advance at the cam. 1-5/8 primary tubes on the headers will keep the torque down low, also run some high-ratio rockers such as 1.7 rollers. All the above tricks with a dual-plane intake is the classic torquer setup, it does everything below 3500 RPM and kicks you in the butt with the torque, its almost like a diesel.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #5 of 8 Old 11-08-2012, 03:06 PM
97wrangler-242
I came here hoping for 4.0 cam choices lol. I also have a sbc though and Pete, I was wondering why you recommend 1.7 rockers for torque down low?
97wrangler-242 is offline
post #6 of 8 Old 11-08-2012, 04:40 PM
ltrail
1984 XJ Cherokee
I thought of the larger rockers also in my choices but there becomes issues with contact of the valve guides when running larger ratio rocker. I also was under the impression that aftermarket "tall" valve covers would be needed at 1.7, these dont come cheap.
ltrail is offline
post #7 of 8 Old 11-09-2012, 07:52 AM
pete1991YJ
Because the high ratio emphasizes the effects of the short-duration low-overlap cam. Which is basically what you want for torque. It opens the valves farther and quicker, even tho the total time the valve is open, is shorter. It also "makes up" for the short amount of time the port is open, by opening the valve further -larger port opening in a short amoount of time, VS a small port opening in a long overlapping time at higher RPM's. The trick of fitting 1.7 rockers onto SBC's was discovered 25 yrs ago but now they make rockers for that instead of having to modify the BBC rockers. Last I heard, the SBC doesn't need special covers for that, but I could be wrong about the covers.
post #8 of 8 Old 11-09-2012, 08:16 AM
ltrail
1984 XJ Cherokee
I had inquired about the 1.7's and the guy said for what I was doing it wasn't fully worth the dollar. My machinist has always been very straightforward on these things. I always use their shop for work and personal builds. The 1.7 even with stock truck cam would have cost me a ridiculous amount not only in the price of rockers but the supporting work to make all of it work together. Different springs to allow the lift without binding, clearance to the guides, and the tall covers were pretty certain. Thinking the largest I could have gone was a 1.6 and I believe that was the Limits of the double spring set I picked.
Depending on how I like my setup I can always 1.6 it later fairly easily without maxing out the springs. So if you keep it all within reason you could do the 1.6.
ltrail is offline
